Setting default opening web page for safari
  • January 28, 2025
  • 42 views
Good day
I want to ask if there is a possibility of setting a default web page that will open when Safari is opened.
we are using Jamf Pro and Ipads
Thank you  for your help
Regards
sdagley
  • January 28, 2025
@B7378 Use a Configuration Profile with an Application and Custom Settings payload configured like this:
Shyamsundar
  • January 29, 2025
try with this below Plist,
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>HomePage</key> <string>Your Home Page URL</string> <key>NewWindowBehavior</key> <integer>0</integer> <key>NewTabBehavior</key> <integer>0</integer> </dict> </plist>
if you want to try with the above-mentioned method using JSON, you can download the safari json using the below link.
https://github.com/Jamf-Custom-Profile-Schemas/ProfileManifestsMirror/blob/main/manifests/ManagedPreferencesApple/com.apple.safari.json
