Setting VNC Password and Enabling remove management
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Posted on
12-08-2017
03:08 AM
- last edited on
03-04-2025
07:11 AM
by
kh-richa_mig
Hi All
I am looking to push out enabling remote management and setting a VNC password.
I have tried running the command bellow and i get a "Command not found" error.
I have attached a screenshot of my terminal window.
If anyone has any tips that would be great.
Thanks Dale
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -access -on -restart -agent -privs -all -clientopts -setvncpw thisIS~[upload](4688e2d58a9f4940be0d5453e0f9fa0a)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-08-2017 07:23 AM
This should enable Apple Remote Desktop
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -allowAccessFor -allUsers -privs -all > /dev/null
Below is how we have setup to configure it and setup VNC password
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -clientopts -setreqperm -reqperm yes -setvnclegacy -vnclegacy yes -setvncpw -vncpw "password you want minus quotes" > /dev/null
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 12-18-2017 09:28 AM
This should enable Apple Remote Desktop sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -activate -configure -allowAccessFor -allUsers -privs -all > /dev/null Below is how we have setup to configure it and setup VNC password sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -clientopts -setreqperm -reqperm yes -setvnclegacy -vnclegacy yes -setvncpw -vncpw "password you want minus quotes" > /dev/null
Hello I am still getting a command not found error when i run this in terminal, is there something i should do prior to running the command?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 01-03-2018 02:01 AM
Does anyone have any suggestions for this
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Posted on 03-31-2020 10:35 PM
sudo /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/Resources/kickstart -configure -clientopts -setreqperm -reqperm yes -setvnclegacy -vnclegacy yes -setvncpw -vncpw "password you want minus quotes" does enable
Anyone may request permission to control screen
VNC viewers may control screen with password
And it seems to be setting the password.
Unfortunately I'm getting password incorrect issue. Tried with or without the quotes.
