I have a shell script that runs as part of a package install after enrollment that helps kick off my SplashBuddy setup.
Stealing (learning from) https://yearofthegeek.net/2018/05/updating-our-depnotify-process/
The process works perfect however now my shell script that gets called is asking for permission to control the Finder. You cannot add a .sh file to the JAMF PPPC Utility any ideas how to build a configuration profile so that popup does not do that?
