Smart group based on LDAP attribute isn't retroactively working
We use one of the custom active directory attributes to designate if someone is a Student, Faculty or Staff. I created a smart group to look at that attribute, so I could have two lists, one list of all the student iPads, and one of all Faculty/Staff iPads.
The two smart groups are working, but only with newly activated devices. For example, the faculty/staff smart group has 3 members in it, but all three were iPads that got set up in the past 3 days or so. The group SHOULD have something like 400 iPads in it though. Any idea why the group is only grabbing new iPads, and not all, with the attribute that I designated?
Best answer by awoodbury
@rahern I just came across this the other day. You will want to make sure "Collect user and location information from LDAP"  is checked for both Computers and Devices.
Settings > Computer Management - Management Framework > Inventory Collection > Check "Collect user and location information from LDAP"
Settings > Device Management > Inventory Collection > Check "Collect user and location information from LDAP"
DBrowning
  • 668 replies
  • April 26, 2022
What is your inventory update frequency?
  • Employee
  • 59 replies
  • April 26, 2022
  • Employee
  • 59 replies
  • April 26, 2022
Yes, this is also a factor too.
mickgrant
  • 140 replies
  • April 28, 2022
if this is a new LDAP attribute that is being pulled, it doesn't happen automatically.
but if you go to a device profile and edit the users and location section, and click search again it will update the LDAP data with any new fields. The device should now appear within your Smart Group
you can do this in bulk with JSSMUT if you update the username (by just rewriting the existing username over it again) it will pull the new LDAP fields on your previously enrolled devices
  • 12 replies
  • May 2, 2022
That did it @awoodbury, thanks so much.
Cookie policy
Cookie settings
