SMART Group Scoping
Is there any way, other than going thru all the profiles and apps 1-by-1, to see what scopings SMART Groups are used in?
  • 7880 replies
  • April 3, 2017
There are scripts and small utilities out there that use the JSS API to help determine where things like groups, packages, scripts and other objects are being used within your JSS structure. Jamf should eventually provide this out of box, but for now, I would search around for some of those to see if they help.
bentoms
Forum|alt.badge.img+35
  • 4331 replies
  • April 3, 2017
@lehmanp00 You can export a JSS summary, select the options for what you're after.. or everything.. then search that.
  • 207 replies
  • April 10, 2017
Did not see anything in the JAMF summary. It had Apps and SMART Groups but it did not show scoping.
Cookie policy
Cookie settings
