testing application with parameters in following script
  • January 25, 2021
  • 0 views
Where I am going wrong in testing application with parameters in following script ?
!/bin/bash
source="/Library/Application Support/JAMF/Waiting Room/abc.app"
target="/Library/Applications/"
mv "$source" "$target"
installer -pkg "/Library/Applications/" -target --quiet --update No --analytics No
1 reply
stevewood
Forum|alt.badge.img+35
  • Employee
  • 1797 replies
  • January 25, 2021
@user-sNVOuZbYdW
Can you re-post your script and make sure you use the code formatting when you post?
But looking at your installer call, it doesn't appear that you're providing a package nor a target. What exactly are you attempting to do? You wouldn't be able to use the .app file with the installer command, so it's not really clear.
Cookie policy
Cookie settings
