Posted on 11-16-2015 11:50 AM
Here's a little nugget that you all can enjoy :-)
I wrote this as we are switching our students to a different SSID, however the one they are on currently will still exist. This script changes the wifi preferred list to set the SSID you choose to the top. It also gives the option to remove a SSID of your choice. Another option this script has is to just remove a SSID rather move a SSID in the list. It has been tested on 10.10 and 10.11, it "should" work on 10.9 but I do not have a machine nearby to test it with.
The script has a check to ensure all settings are filled with input or it exits with what is missing. Here is a picture of the script options in Casper:
# /bin/bash
#This script is made to change the priority of the Wifi SSID's
#It has been tested and does not de-auth the user if they are currently on the SSID to be changed (If the SSID password remains in the keychain)
#This has been tested on 10.10 and 10.11
#Sets arguements for script
NetworkDevice=$4
PreferredNetwork=$5
WirelessSecurity=$6
RemoveNetworkAlso=$7
#Only fill NetworkDevice if using RemoveNetworkOnly. It will not run the other arguements
RemoveNetworkOnly=$8
#Setting argument to anything will trigger this to be run (i.e. asdfasdf) Make sure NetworkDevice is set. Will run with RemoveNetworkOnly
ShowPreferred=$9
#As stated above, if the RemoveNetworkOnly field is populated the script will only run the very last command.
if [ -z $RemoveNetworkOnly ]; then
#Checks if all arguements have been entered, will exit out with statement if no settings have been set.
if [ -z $NetworkDevice ]; then
echo "Please set the NetworkDevice"
exit 1
if [ -z $PreferredNetwork ]; then
echo "Please set the Preferred Network SSID"
exit 1
if [ -z $WirelessSecurity ]; then
echo "Please set the Wireless Security Type"
exit 1
#Echos all arguements
echo "Network Device is $NetworkDevice"
echo "Preferred Network SSID is $PreferredNetwork"
echo "Wireless Security Type is $WirelessSecurity"
#Changes Priority of SSID to 0
networksetup -removepreferredwirelessnetwork "$NetworkDevice" "$PreferredNetwork"
networksetup -addpreferredwirelessnetworkatindex "$NetworkDevice" "$PreferredNetwork" 0 "$WirelessSecurity"
#If RemoveNetworkAlso is populated it will run otherwise the script will close
if [ -z $RemoveNetworkAlso ]; then
networksetup -removepreferredwirelessnetwork "$NetworkDevice" "$RemoveNetworkAlso"
echo Done
exit 1
echo "Unknown error, check to make sure script has not been edited"
exit 1
networksetup -removepreferredwirelessnetwork "$NetworkDevice" "$RemoveNetworkOnly"
#If arguement is filled with yes it will show preferred list *Warning can be a large list*
if [ -z $ShowPreferred ]; then
echo Done
networksetup -listpreferredwirelessnetworks "$NetworkDevice"
Posted on 12-03-2015 07:31 AM
Here is the updated script since the last post, it can now auto-detect which EN port is WiFi. I've also added the ability to change priority numbers (0 being top of list). Below is the setup for the script settings.
# /bin/bash
#This script is made to change the priority of the populated SSID to 0 (Top of list)
#Disabled NetworkDevice as NetworkPort will auto-detect WiFi port location
Priority=$4
PreferredNetwork=$5
WirelessSecurity=$6
#Running RemoveNetworkOnly populated will not run other options
#Setting argument $9 to anything will trigger this to be run (i.e. asdfasdf) Will run with RemoveNetworkOnly
ShowPreferred=$9
#Sets arguement to check for port location of wifi, nulls need of NetworkDevice.
NetworkPort=`/usr/sbin/networksetup -listallhardwareports | grep -A 1 Wi-Fi | grep Device | cut -d' ' -f2`
if [ -z $NetworkPort ]; then
echo "WiFi Port not detected, please ensure system has WiFi capabilities"
exit 1
exit 1
exit 1
echo "Network Device is $NetworkPort"
networksetup -removepreferredwirelessnetwork "$NetworkPort" "$PreferredNetwork"
networksetup -addpreferredwirelessnetworkatindex "$NetworkPort" "$PreferredNetwork" "$Priority" "$WirelessSecurity"
echo "Priority changed"
networksetup -removepreferredwirelessnetwork "$NetworkPort" "$RemoveNetworkAlso"
echo "SSID $RemoveNetworkAlso Removed"
exit 1
exit 1
networksetup -removepreferredwirelessnetwork "$NetworkPort" "$RemoveNetworkOnly"
echo "SSID Removed"
#If arguement is populated it will show preferred list *Warning can be a large list*
#Do not rely fully on this as it can have false reporting, having a sleep time has not helped.
echo Done
networksetup -listpreferredwirelessnetworks "$NetworkPort"
Posted on 03-14-2016 01:12 PM
You are the man!!! Thanks @jjones
Posted on 10-31-2016 09:53 AM
Script worked great to put our preferred wi-fi network atop users' network lists.
But, putting the preferred network into Parameter 5 and then the network to remove in Parameter 7 didn't seem to work -- it put the preferred network atop the list but didn't remove the other.
Creating a separate policy with the network to remove in Parameter 8 while leaving Parameters 4-7 blank did the trick.
Posted on 01-06-2017 01:49 PM
How about for iOS???
Posted on 01-09-2017 04:37 AM
When running this script its actually removed my corporate entry and then re-added it without any security. What have I done wrong? This would remove all instances and make every device drop off the corporate network!
Script Results:
Running script Preferred Network SSID...
Script exit code: 0
Script result: /Library/Application Support/JAMF/tmp/Preferred Network SSID: line 31: [: WPA2: binary operator expected
Network Device is en0
Preferred Network SSID is "Corporate SSID"
Wireless Security Type is WPA2 Enterprise
Removed "Corporate SSID" from the preferred networks list
Security type is set to: Open
Added "Corporate SSID" to preferred networks list
Priority changed
Network was not found in the preferred networks list
Posted on 11-19-2017 04:26 PM
I got the same thing.
If I set the Security type to WPA2 Enterprise, it just sets it to None.
If I set it as just WPA2, it defaults to WPA2 Personal.
Any ideas??
Posted on 11-20-2017 05:55 AM
@iamgriffin See the script in the linked post which works with WPA2 Enterprise authenticated SSIDs (it sorts the SSID list directly rather than deleting and re-adding SSIDs as the script above does): Re-order WIFI Preferred Networks...
Posted on 08-07-2018 09:37 PM
To set wireless encryption type use:
"WPA2E"
Posted on 11-12-2018 05:50 PM
Thank you.
