Zoom and Outlook Plugin Install and Update
  • February 20, 2020
  • 35 views
I have found this great script that does install and update for zoom client, but it doesn't do anything for outlook plug in. is there any way to incorporate that in to this script?
# ABOUT THIS PROGRAM
# NAME
#       ZoomInstall.sh -- Installs or updates Zoom
# SYNOPSIS
#       sudo ZoomInstall.sh
# HISTORY
#       Version: 1.1
#       1.1 - Shannon Johnson, 27.9.2019
#       Updated for new zoom numbering scheme
#       Fixed the repeated plist modifications
#       1.0 - Shannon Johnson, 28.9.2018
#       (Adapted from the FirefoxInstall.sh script by Joe Farage, 18.03.2015)
# Script to download and install Zoom.
# Only works on Intel systems.
# Set preferences
hdvideo="true"
ssodefault="true"
ssohost="psu.zoom.us"
# choose language (en-US, fr, de)
lang=""
# CHECK TO SEE IF A VALUE WAS PASSED IN PARAMETER 1 AND, IF SO, ASSIGN TO "lang"
if [ "$4" != "" ] && [ "$lang" == "" ]; then
        lang=$4
        lang="en-US"
pkgfile="ZoomInstallerIT.pkg"
plistfile="us.zoom.config.plist"
logfile="/Library/Logs/ZoomInstallScript.log"
# Are we running on Intel?
if [ '`/usr/bin/uname -p`'="i386" -o '`/usr/bin/uname -p`'="x86_64" ]; then
        ## Get OS version and adjust for use with the URL string
        OSvers_URL=$( sw_vers -productVersion | sed 's/[.]/_/g' )
        ## Set the User Agent string for use with curl
        userAgent="Mozilla/5.0 (Macintosh; Intel Mac OS X ${OSvers_URL}) AppleWebKit/535.6.2 (KHTML, like Gecko) Version/5.2 Safari/535.6.2"
        # Get the latest version of Reader available from Zoom page.
        latestver=`/usr/bin/curl -s -A "$userAgent" https://zoom.us/download | grep 'ZoomInstallerIT.pkg' | awk -F'/' '{print $3}'`
        echo "Latest Version is: $latestver"
        # Get the version number of the currently-installed Zoom, if any.
        if [ -e "/Applications/zoom.us.app" ]; then
        currentinstalledver=`/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleVersion | sed -e 's/0 //g' -e 's/(//g' -e 's/)//g'`
                echo "Current installed version is: $currentinstalledver"
                if [ ${latestver} = ${currentinstalledver} ]; then
                        echo "Zoom is current. Exiting"
                currentinstalledver="none"
                echo "Zoom is not installed"
        url="https://zoom.us/client/${latestver}/ZoomInstallerIT.pkg"
        echo "Latest version of the URL is: $url"
        echo "`date`: Download URL: $url" >> ${logfile}
        # Compare the two versions, if they are different or Zoom is not present then download and install the new version.
        if [ "${currentinstalledver}" != "${latestver}" ]; then
                # Construct the plist file for preferences
                echo "<?xml version="1.0" encoding="UTF-8"?>
                 <plist version="1.0">
                 <dict>
                        <key>nogoogle</key>
                        <string>1</string>
                        <key>nofacebook</key>
                        <string>1</string>
                        <key>ZDisableVideo</key>
                        <true/>
                        <key>ZAutoJoinVoip</key>
                        <true/>
                        <key>ZDualMonitorOn</key>
                        <true/>" > /tmp/${plistfile}
                if [ "${ssohost}" != "" ]; then
                        echo "
                        <key>ZAutoSSOLogin</key>
                        <true/>
                        <key>ZSSOHost</key>
                        <string>$ssohost</string>" >> /tmp/${plistfile}
                echo "<key>ZAutoFullScreenWhenViewShare</key>
                        <true/>
                        <key>ZAutoFitWhenViewShare</key>
                        <true/>" >> /tmp/${plistfile}
                if [ "${hdvideo}" == "true" ]; then
                        echo "<key>ZUse720PByDefault</key>
                        <false/>" >> /tmp/${plistfile}
                echo "<key>ZRemoteControlAllApp</key>
                        <true/>
                </dict>
                </plist>" >> /tmp/${plistfile}
                # Download and install new version
                /bin/echo "`date`: Current Zoom version: ${currentinstalledver}" >> ${logfile}
                /bin/echo "`date`: Available Zoom version: ${latestver}" >> ${logfile}
                /bin/echo "`date`: Downloading newer version." >> ${logfile}
                /usr/bin/curl -sLo /tmp/${pkgfile} ${url}
                /bin/echo "`date`: Installing PKG..." >> ${logfile}
                /usr/sbin/installer -allowUntrusted -pkg /tmp/${pkgfile} -target /
                /bin/sleep 10
                /bin/echo "`date`: Deleting downloaded PKG." >> ${logfile}
                /bin/rm /tmp/${pkgfile}
                #double check to see if the new version got updated
                newlyinstalledver=`/usr/bin/defaults read /Applications/zoom.us.app/Contents/Info CFBundleVersion`
        if [ "${latestver}" = "${newlyinstalledver}" ]; then
                /bin/echo "`date`: SUCCESS: Zoom has been updated to version ${newlyinstalledver}" >> ${logfile}
                # /Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType hud -title "Zoom Installed" -description "Zoom has been updated." &
                /bin/echo "`date`: ERROR: Zoom update unsuccessful, version remains at ${currentinstalledver}." >> ${logfile}
                /bin/echo "--" >> ${logfile}
                        exit 1
        # If Zoom is up to date already, just log it and exit.
                /bin/echo "`date`: Zoom is already up to date, running ${currentinstalledver}." >> ${logfile}
        /bin/echo "`date`: ERROR: This script is for Intel Macs only." >> ${logfile}
1 reply
beeboo
  • January 20, 2021
hey @ekarazhov , here is an excerpt you can use
echo "Begin process to install or update of Zoom for Mac Outlook Plugin"
##            VARIABLES               ##
osURL=$(sw_vers -productVersion | sed 's/[.]/_/g')
agent="Mozilla/5.0 (Macintosh; Intel Mac OS X ${osURL}) AppleWebKit/535.6.2 (KHTML, like Gecko) Version/5.2 Safari/535.6.2"
# Gets latest version of PKG
# Latest version as of testing is:
# Curl result: 5.4.59712.1217
# Plist result: 5.4.59712
# Note that CFBundleShortVersionString = 5.4.59712 and CFBundleVersion = 2020.12.17
# Curl result appends the CFBundleVersion(without the periods) to CFBundleShortVersionString
latestVERSION=$(curl -s -A "$agent" https://zoom.us/download | grep 'ZoomMacOutlookPlugin.pkg' | awk -F'[()]' '{print $4}' | cut -d' ' -f2)
# Full fat version: 5.4.59712.1217
echo "Latest version: $latestVERSION"
# Trimmed version: 5.4.59712
echo "Formatted Latest version: $(echo $latestVERSION | sed 's/.[^.]*$//'))"
# What CURL will name the installer PKG instead of versioning so theres less variables
pkgFILE="/private/tmp/ZoomMacOutlookPlugin.pkg"
# Latest verison of the plugin
installedVERSION=$(defaults read /Applications/ZoomOutlookPlugin/PluginLauncher.app/Contents/Info.plist CFBundleShortVersionString)
echo "Installed verison: $installedVERSION"
# Lists PID(s) of Microsoft Outlook
process=$(pgrep -f "Microsoft Outlook")
##            FUNCTIONS               ##
installPLUGIN() {
    echo "Beginning installation for latest version"
    echo "Downloading PKG file"
    url="https://zoom.us/client/latest/ZoomMacOutlookPlugin.pkg"
    curl -sLo "$pkgFILE" ${url}
    echo "Installing PKG"
    installer -allowUntrusted -pkg "$pkgFILE" -target /
    sleep 5
    echo "Deleting downloaded PKG"
    rm -v -rf /private/tmp/ZoomMacOutlookPlugin.pkg
    echo "Clean up complete - file deleted"
openOUTLOOK() {
    currUSER=$(stat -f "%Su" /dev/console)
    currUSERid=$(id -u "$currUSER")
    launchctl asuser $currUSERid sudo -iu $currUSER open -a /Applications/Microsoft Outlook.app
my script is separate from my zoom IT script just in case some people dont want the plugin.
How you distribute it at this point is up to you, i just do a deployment type and go from there (silent, prompt, etc)
