@DennisMX from what I am being told it is filed as an active PI by Jamf and they are working with Apple. See this discussion for more info:
vpp redownload call timed out <mdmclienterror:72>
You also found that, but it doesn't seem to have any priority if they are looking at it since february.
Could it just be as simple as Apple blocking all connections from Jamf devices due to possible DDOS?
Some times it works, maybe if you try at a less crowded time?
@DennisMX Apple and Jamf have been actively investigating this together for a month so far, patience is a virtue.
I've had a little luck with this process...
1) Turn WiFi off on Mac
2) Cancel all pending and failed commands
3) Push a new Application that has yet to be pushed to the Mac. Something random or new, it doesn't matter as long as it wasn't provisioned to the Mac up to this point.
4) WiFi back on
5) If you can get this new app to download and install, the rest of the apps that are queued up should start downloading.
This has worked for me for 2 out of 3 of the last machines I erased and re-provisioned for new users. Definitely not a good solution for shops on-boarding more than a handful of people a week.
@krismonier Will test this...
It seems that this issue is getting worse every day.
It went from seeing the issue sporadic, to sporadic having the mac store apps installed.
@krismonier Plus one, it's gotten much worse this week.
I am experiencing the same. I had see the issue occasionally in the past but with a clear of the errors the install would work. I have been trying for the last 2 days off and on to get any apps to install. I will try the above mentioned workaround but someone needs to light a fire under the developers to get this resolved. I am just glad I am only working on a machine as a replacement and not for a new employee. That would create quite the embarrassing situation for me as I don't have time or packages to do these installs another way.
Seeing this with our VPP installs of Xcode the most.
We had issues starting around 10AM 2 days ago - when we signed into Apple Business manager, the Apps and Books pane loaded a message about the store being unavailable.
Checked around 1115 and the store was back. Cleared failed and pending management commands, ran recon and the VPP apps came down on 2 of the 3.
The third device I had to exclude the device from scope on each of the VPP apps, clear failed and pending management commands, and reboot. Then I un-excluded the device from one of the Apps (Microsoft Outlook) & it installed. Un-excluded the others one by one and each started to install within 2 seconds of saving Application scope.
Updating - VPP fell down for us Friday Oct 25 and didn't clear itself up after rounds of clearing pending commands and running recon. Had to revert to pkg installs for Office and XCode.
Yesterday, needed Microsoft Remote Desktop from VPP and was able to install properly after doing this:
- Uncheck "Assign VPP Content", save
- Edit, recheck "Assign VPP Content", save
This was needed on each Mac App Store App to get them going again.
GREAT TIMING OF THIS POST...I started seeing this show up!
Anyone got it working or any other tricks?
tried the @merps suggested, but no luck still fails:
VPP redownload call timed out <MDMClientError:72>
We have tried this repeatedly today and still no luck. even for small apps like Slack or Trello
Our organization reverted back to packaging the O365 apps because of this.
We have reverted to pushing packages also. not fun.
@esv @landon_Starr our fix worked for just a day or so, and now I’ve reverted back to packaging MS office and Xcode. Luckily we weren’t trying to use VPP for anything else on macOS.
This has been happening for about 3 or 4 months for 1 organisation we looked after. Good luck waiting for Apple and Jamf to sort this.
Only seems to be an issue with Jamf Pro other MDMs fine.
@jonohayes I’ve heard other MDMs are affected including MobileIron & InTune so clearly not just Jamf.
This has been an issue for a while now no sign of a fix anytime soon.
https://www.jamf.com/jamf-nation/discussions/31057/vpp-redownload-call-timed-out-mdmclienterror-72
Everything points to an Apple problem and we all know enterprise Mac developments are Very Very low on their lists.
Honestly, this longstanding bug is seriously making me reconsider ever deploying Apps to Macs via the Mac App Store ever again. It'd be one thing if it was just a temporary glitch, but this is now many months old, is intermittent, unpredictable, and makes everyone look bad -- Apple, my Tech Department, me (as the architect of the deployment), the Macs themselves, Jamf (and other MDM solutions). You think the end user cares who is at fault? All they know is that they are trying to install an App via Self Service (as they've been instructed to do) and it often fails.
Would be nice to get more details from Apple but so far nothing.
Remind me... WHAT was the benefit we were to receive from utilizing this method? Seems we CONTINUE to come up kinda short... :-/
Hi all, I'm a new Jamf Pro user and this has been doing my head in – I haven't been seeing the error in the Device > Management > Failed Commands because I think they clear out after a while. I've happened to spot the multiple failed commands on a device I'm trying to deploy this evening.
Oddly the typical culprits tend to be MS Office Apps (Word, Powerpoint, Excel, Outlook) but I get this on occasion with Slack, Keynote, Numbers and Pages as well.
I've noticed this thread hasn't been active since April 2020. Has anyone found a fix? The main way I've found to sort the issue is to go to the software in the Jamf > Mac App Store Section > unscope it and then rescope it / save. This sends a new push to the devices.
Quite frustrating as this is compromising the promise of 'zero touch deployment'.
Would really appreciate any tips.
I'm seeing error 72 with VPP Big Sur installer.
Hello Jamf and Apple? This issue has persisted for years...
