BeyondTrust is telling us that the only way the "support deployment is through ARD." We are not huge fans of ARD. Has anyone been able to deploy with Jamf and the provided DMG? If so do you mind sharing how.
- Home
- Community
- Get Support
- General Discussions
- Deploy BeyondTrust with Jamf
- May 15, 2020
- 50 replies
- 710 views
- Valued Contributor
- May 15, 2020
Which product from BeyondTrust? Thy have bought up a bunch of stuff recently.
- Author
- New Contributor
- May 15, 2020
Great question, we are using the Secure Remote Access Jump Client.
- Contributor
- May 15, 2020
Hi @IndianaChris,
If you are referring to installing the remote support client (previously called Bomgar), you can take a look at this thread Deploying Bomgar JumpClient to Macs using Casper
- June 30, 2020
I checked BeyondTrust's web site and they still only list the their old Bomgar documentation about using Automator and ARD to mount a DMG, etc. However the installer is no longer ON a disk image. It's a standalone app (yes, an app... sigh). I'm looking into this too, but it MIGHT be as simple as installing it in /var/tmp/ and using open /var/tmp/Open To Deploy Jump Client.app. You'll probably need a user environment to run it in though.
Edit: Even with running this as root (sudo), there's still a prompt for local credentials to make changes.
- Honored Contributor
- June 30, 2020
@IndianaChris We're using @mm2270's App Packager for the bomgar-rep-installer.dmg.
- June 30, 2020
Sigh, update. I missed the 'programmatic' download option, which contains sdcust in the applications...
- June 30, 2020
If I run the install manually from the command line...sudo hdiutil attach /private/var/tmp/bomgar-scc*.dmgsudo /Volumes/bomgar-scc/Double-Click To Start Support Session.app/Contents/MacOS/sdcust
...it installs fine.
If I do the same thing in a post-install script as part of a package that puts the dmg in the same place, the splash screen comes up for a while, and it eventually goes away without anything being installed.
I don't understand why and I can't find any type of reference in a log anywhere (looked in console for sdcust, Bomgar, beyond trust, etc).
- New Contributor
- August 18, 2020
Interesting. We use Bomgar/Beyond Trust in our environment for remote support. We don't install any agents -- just a config profile on all machines that will allow the app to do it's thing. We have the use go to a website and click on the technicians name and it will initiate a remote session where the client will download and run a quick package. Allow screen recording and accept the connection. Done.
- August 19, 2020
@david.maestre but you're not installing the jump client to remote into the machine when a user isn't there. I've got the PPPC setup for most of it, but in 10.15 it prompts to allow screen recording, which I'd think happens even with user-initiated sessions...
- New Contributor
- November 11, 2020
@cwaldrip This is correct we've tried remote portal and it does prompt to allow screen recording which then requires the user to restart the remote session before control can be had. We have upgraded our base to 6.1 and jump agents to 20.1.1. We now see the .app and have tried multiple ways to deploy and run a post script to install the .app installer without success. Has anyone figured this out as I have an open case with Bomgar with no pathway to success yet.
- November 11, 2020
Is the issue you're experiencing around the screen recording prompt, or getting the jump client installer to work?
If the former, this is a macOS restriction in Catalina and above, and I'm not aware of a workaround. If the latter, I'd be happy to share my postinstall script. It did take a bit of trial and error to get it working, main thing is to make your installers valid for a year (the maximum) or you'll find yourself re-packaging it a lot.
- November 11, 2020
@IndianaChris Look at this script to deploy this.
Steps:
1. Create the jump client dmg from the Bomgar console
2. Create policy in Jamf to Cache the dmg and run this script after.
3. Scope and deploy.
# The Bomgar DMG should have been installed cached prior to this script running, but we should make sure...
if [ -a "/Library/Application Support/JAMF/Waiting Room/bomgar-scc-"*".dmg" ]; then
# Attach the Disk Image
hdiutil attach /Library/Application Support/JAMF/Waiting Room/bomgar-scc-*.dmg
# Run the installer
# Wait a minute for it to finish up
sleep 90
# Unmount the disk image
hdiutil detach /Volumes/bomgar-scc
# Wait for the unmount to complete
sleep 25
# Delete the disk image
rm -R /Library/Application Support/JAMF/Waiting Room/bomgar-scc-*.dmg
echo "Bomgar NOT Present"
exit 1
exit 0- New Contributor
- December 3, 2020
@kericson when I use that script the jump client installs correctly but the the security/privacy preferences aren't set. Was wondering what would be the best way to set those item when installing the actual jump client using that script?
- New Contributor
- December 3, 2020
Here is the script I'm running:
BOMGAR_URL='https://it-fileshare-files-179wwtfhkyps2.s3-us-west-2.amazonaws.com/IT/Mac/BomgarProgrammatic.dmg'
DMG_PATH='/tmp/BomgarProgrammatic.dmg'
/usr/bin/curl --silent "${BOMGAR_URL}" --output "${DMG_PATH}"
if [ -a "${DMG_PATH}" ]; then
hdiutil attach "${DMG_PATH}"
# # Run the installer
/Volumes/bomgar-scc/Double-Click To Start Support Session.app/Contents/MacOS/sdcust --silent
# # Wait a minute for it to finish up
# sleep 60
# # Unmount the disk image
# hdiutil detach /Volumes/bomgar-scc
# # Wait for the unmount to complete
# sleep 15
# # Delete the disk image
# rm -R "${DMG_PATH}"
fi- New Contributor
- December 3, 2020
I'm then receiving this error output:
Script result: Checksumming Protective Master Boot Record (MBR : 0)…
Protective Master Boot Record (MBR :: verified CRC32 $E2F8D74C
Checksumming GPT Header (Primary GPT Header : 1)…
GPT Header (Primary GPT Header : 1): verified CRC32 $6E0A0204
Checksumming GPT Partition Data (Primary GPT Table : 2)…
GPT Partition Data (Primary GPT Tabl: verified CRC32 $E4C3873D
Checksumming (Apple_Free : 3)…
(Apple_Free : 3): verified CRC32 $00000000
Checksumming disk image (Apple_HFS : 4)…
disk image (Apple_HFS : 4): verified CRC32 $F182C998
Checksumming (Apple_Free : 5)…
(Apple_Free : 5): verified CRC32 $00000000
Checksumming GPT Partition Data (Backup GPT Table : 6)…
GPT Partition Data (Backup GPT Table: verified CRC32 $E4C3873D
Checksumming GPT Header (Backup GPT Header : 7)…
GPT Header (Backup GPT Header : 7): verified CRC32 $1AECF169
verified CRC32 $FF3EC199
/dev/disk2 GUID_partition_scheme
/dev/disk2s1 Apple_HFS /Volumes/bomgar-scc
20201202 18:43:32 999999 19811:main(19affdc0) UTIL:INFO>license file: '/Volumes/bomgar-scc/Double-Click To Start Support Session.app/Contents/Resources/server.lic'
Let me know if anyone has any insights
- December 3, 2020
@jimmychi Which script are you using? The security/privacy preferences can't only be set with a PPPC profile and one part the user has to approve no way to automate per Apple.
- New Contributor
- December 3, 2020
@kericson I'm using the following script:
# sleep 60
# sleep 15
Previously that script worked for us and we didn't have to set any security/privacy preferences so was trying to fix it but to no success. Was wondering how we would set the PPPC profile for screen recording and to allow the bomgar jump client?
- Contributor
- January 8, 2021
@jimmychi You can't pre-authorize screen recording for any app. The use MUST authorize screen recording. Hard limit from Apple.
BTW, I managed to deploy Remote support button through Self Service, but it seems to fail with the same kind of error when mass deploying the Remote support button, because the install is done in root context when there is no session opened. Bummer.
- Contributor
- January 19, 2021
Our script, similar to the above, used to work fine for installing the Jump Client - and still does - just not for Big Sur.
During installation on Big Sur the user runs into the dialog:
"Double-Click To Start Support Session" can't be opened because Apple cannot check it for malicious software. This software needs to be updated. Contact the developer for more information.
Really? They posted Big Sur support in the release notes but gave us no way to install via MDM? Is there any way around this via Jamf?
- Contributor
- January 19, 2021
Allow me to answer my own question. The app can be pulled out of quarantine manually.
Added to the script - copy the app to /tmp/ and remove it from quarantine and then run it from there instead of the volume.
cp -R '/Volumes/foobar/Double-Click To Start Support Session.app' '/tmp/Double-Click To Start Support Session.app'
xattr -d com.apple.quarantine '/tmp/Double-Click To Start Support Session.app'
- New Contributor
- January 19, 2021
If you're on the MacAdmins Slack, join the Bomgar channel. A BeyondTrust employee posted a PDF that will eventually replace the KB article on the BeyondTrust site for mass deployment.
Here's a direct link: https://macadmins.slack.com/archives/CEH9Y26D6/p1606838240060700
- January 20, 2021
@patgmac I don't have an acct to that slack workspace. Can you copy the PDF here please
- New Contributor
- January 21, 2021
@sgiesbrecht there is no way to attach files here. It's free to sign up for that Slack and it's a great place to hang out and get help.
- New Contributor
- September 7, 2021
david_maestre Your method was working fine with Big Sur Mac machines.. So in this case only PPPC is enough and we can able to take remote of user machines without any issues. FYI, We can allow screen recording and accessibility through PPPC itself. Cheers buddy...
- Contributor
- December 10, 2021
Can't access the direct link for Slack.
Any more hints for this problem ?
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OK
