Configuration Profiles > Login Items > Network Mounts - Broken?
  • June 16, 2021
  • 8 replies
  • 106 views
I'm trying to get a network volume mounted automatically at login.
The volumes are on an AFP server. In Jamf Pro I am using Configuration Profiles > Login Items > Network Mounts and entering the following:
afp://myserver.mycompany.com/MyVolume
On client computers I can see in Utilities > System Information > Software Profiles that the loginitems.managed item is being pushed correctly to the client, with the correct afp path as above.
However, no volume is mounted at login. In System Preferences > Users & Groups > CurrentUser > Login Items a volume is shown, but there is no path - only "/".
I can see discussion that others have problems with this payload. Is it expected to work at all with 10.14 and 10.15?
Thanks,
ft.
  • June 21, 2021
as this is broken a long time already, we moved to something which is way more reliable. Check out https://gitlab.rrze.fau.de/faumac/networkShareMounter
Thanks to RRZE for this great tool!
Cheers
LRZ/bofh
Ah, ok, thanks for confirmation it is broken.
Why is it still in the Jamf Pro interface if it's broken? I spent a bunch of time trying to get it to work.
I'm new to Jamf. Are there any good resources which show the broken parts of Jamf so I don't waste more time on broken stuff?
thanks,
ft.
8 months later it still seems broken for afp and smb.
Are they gonna fix it? Why is it still available if it's broken?
  • April 14, 2022
Just found this thread. It is still broken for me on Mac OS 12.2.1. Still trying to find a solution for unbound Macs to auto-magically connect to network drives that the user has access to.
doschupp
  • April 20, 2022
Thanks @LRZ_Jamf for recommending our tool :-)
@DavidN, a few months ago we released a whole new version. Significantly easier to control and users can now add custom shares by themself in the menubar. Maybe that solves your problem? We post a few more details in another thread: https://community.jamf.com/t5/jamf-pro/mounting-smb-network-shares-using-jamf-configuration-profiles/m-p/256569/highlight/true#M237804
  • September 29, 2022
@doschuppwe're eagerly trying to test networkShareMounter however the releases give a 500 error when trying to download.
Can haz fix?
Please and thank you.
doschupp
Can haz fix?
fixed
  • September 7, 2023
fixed
Is this fixed yet in Jamf Pro? My testing would indicate the answer to be no. But if anyone has found anything please let us know.
