This is in response to this:
https://community.jamf.com/t5/community-updates/knowledge-base-articles/td-p/202
Did the comments under some of those articles also make it over? Some of the comments were super helpful sometimes in clarifying issues people would run into because documentation either wasn't clear or the problems were related to third party changes.
I really hope the comments aren't lost. If they are, is there a way to add the ability to comment on knowledge base articles again?
Hey @bpavlov I responded to your comment on the knowledge base post. To prevent confusion, would you mind deleting this post? Thanks!
I don't have the ability to delete posts. Sorry about creating the separate discussion. Still getting used to the new site.
