Druva inSync Current mac Active / Inactive status via Druva UAPI Computer Extension Attribute Script
  • October 8, 2021
  • 48 views
akamenev47
This is something I have been wishing for a while and decided to put it together myself. It is ready to be used as a JSS Computer Extension Attribute if you want to automate Druva inSync re-install/re-activate via Smart Group or simply obtain a list of computers on which Druva inSync is currently Inactive.
Please note: the script is using jq JSON parser, which can be installed on each mac using only a script as I posted here: https://community.jamf.com/t5/jamf-pro/homebrew-and-js-deloyment-using-only-scripts/td-p/247472
You can get the script here on my gist: https://gist.github.com/shurkin18/2c0a1e454f5dbac8b91cfca5893e7722
Or from below:
#!/bin/bash ########################################################################################################################################################################## ########################################################################################################################################################################## # This is a UAPI script which checks for Druva inSync client activation status based on the current mac name # You need to first add Druva API credentials for this script, you can check that documentation here: https://developer.druva.com/docs/introduction # # It can be used on JSS as an Extension Attribute # # Please note: this script requires jq JSON parser to be installed on the mac, otherwise the script won't work # If you are using JAMF JSS, you can read how jq can be pushed via homebrew using only scripts: # https://community.jamf.com/t5/jamf-pro/homebrew-and-js-deloyment-using-only-scripts/td-p/247472 # # Created by Aleksandr Kamenev / shurkin18@gmail.com ########################################################################################################################################################################## ########################################################################################################################################################################## #Druva API credentials druvaApiURL="https://apis.druva.com" usernameclientID="XXXXXXXXXXXXXXXXXXXXXXXXXXXXX" passwordsecretKEY="XXXXXXXXXXXXXXXXXXXXXXXXXXXXX" ################################################################ # DO NOT TOUCH BELOW UNLESS YOU KNOW WHAT YOU ARE DOING! ####### ################################################################ # created base64-encoded credentials encodedCredentials=$( printf "$usernameclientID:$passwordsecretKEY" | /usr/bin/iconv -t ISO-8859-1 | /usr/bin/base64 -i - ) # generate an auth token authToken=$( /usr/bin/curl -X POST -H "authorization: Basic $encodedCredentials" -d "grant_type=client_credentials&scope=read" $druvaApiURL/token ) # parse authToken for token, omit expiration token=$( /usr/bin/awk -F \\" '{ print $4 }' <<< "$authToken" | /usr/bin/xargs ) #Debugging #echo "encodedCredentials are: $encodedCredentials" #echo "authToken is: $authToken" #echo "token is: $token" #/////////////////////// #Start the UAPI scripts# #Current machine name currentmacname=$(hostname) #echo $currentmacname #Obtain the current device status based on the current machine name insyncactivationstatus=`curl --request GET \\ --url "$druvaApiURL/insync/endpoints/v1/devices" \\ --header "Accept: application/json" \\ --header "Authorization: Bearer $token" | jq | grep '"deviceName": "'$currentmacname'"' -A 20 | grep "deviceMarkedInactive" | awk -F '"' '{ print $3 }' | sed 's/://g' | head -n 1` echo "inSync activation status: $insyncactivationstatus" #Check if Druva is activated and if so provide <result> for JSS extension attribute if [ $insyncactivationstatus == "false" ];then echo "<result>Activated</result>" else echo "<result>Not Activated</result>" fi #End of the UAPI scripts# #\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ exit 0
markopolo
  • November 14, 2022
Thanks for sharing this script! I'm getting this on output, any idea what I'm doing wrong?
% Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 176 100 136 100 40 218 64 --:--:-- --:--:-- --:--:-- 285 % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 1 1161k 1 18582 0 0 5749 0 0:03:26 0:00:03 0:03:23 5761 curl: (23) Failure writing output to destination inSync activation status: /Users/testuser/Downloads/EA_Test.sh: line 57: [: ==: unary operator expected <result>Not Activated</result>
akamenev47
  • November 14, 2022
Hmm,
This is pretty generic, often I saw this simply due to minor mistakes in code, like miss-types and such, make sure your DRUVA API URL is correct and you are able to run a simple GET API call with it on the Druva API end.
