homebrew and js deloyment using only scripts
  • September 23, 2021
  • 8 replies
  • 176 views
akamenev47
So, I have modified the classic LAPS API script to work over the new Jamf Pro UAPI (you can check it out it here: JAMF UAPI LAPS script ), did not realizing it will only work if jq binary is installed and working on the mac, so I am trying to put together a policy to install jq at enrollment complete and to push it to all the macs which don't have it currently installed.
What I have tried:
  1. Package the jr binary from my work mac, where jq is installed and working from /usr/local/bin/ using Composer
  2. To make sure it will be executable, I added "Execute Command" to the policy: chmod +x /usr/local/bin/jq​
But if I check for it via: which -a jq or try running curl with jq pipe - it can't find it...
I thought maybe $PATH is set incorrectly, but it looks alright to me:
akamenev@MacBook-Pro bin % ls -lh total 0 lrwxr-xr-x 1 root wheel 89B Sep 22 17:41 authchanger -> /Library/Security/SecurityAgentPlugins/JamfConnectLogin.bundle/Contents/MacOS/authchanger lrwxr-xr-x 1 root wheel 24B Sep 22 17:41 jamf -> /usr/local/jamf/bin/jamf lrwxr-xr-x 1 root wheel 29B Sep 22 17:43 jamfAgent -> /usr/local/jamf/bin/jamfAgent lrwxr-xr-x 1 root wheel 23B Sep 23 10:28 jq -> ../Cellar/jq/1.6/bin/jq akamenev@MacBook-Pro bin % echo $PATH /usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin akamenev@MacBook-Pro bin % which -a jq jq not found
Am I missing something here? Or maybe someone had experience loading jq by itself?
Best answer by akamenev47
So, I was not able to extract jq or install jq by itself, but was able to trim autobrew script so it installs without the policy getting stuck and adding a Files and Processes > Execute Command, which successfully pushes jq and UAPI JSON is working now, whew!
Here is the trimmed autobrew script:
I have added to the script the permissions command:
currentuser=`stat -f "%Su" /dev/console` chown -R $currentuser /usr/local/lib#!/bin/sh # AutoBrew - Install Homebrew with root # Source: https://github.com/kennyb-222/AutoBrew/ # Author: Kenny Botelho # Version: 1.2 # Set environment variables HOME="$(mktemp -d)" export HOME export USER=root export PATH="/usr/local/sbin:/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin" BREW_INSTALL_LOG=$(mktemp) # Get current logged in user TargetUser=$(echo "show State:/Users/ConsoleUser" | \\ scutil | awk '/Name && ! /loginwindow/ { print $3 }') # Check if parameter passed to use pre-defined user if [ -n "$3" ]; then # Supporting running the script in Jamf with no specialization via Self Service TargetUser=$3 elif [ -n "$1" ]; then # Fallback case for the command line initiated method TargetUser=$1 fi # Ensure TargetUser isn't empty if [ -z "${TargetUser}" ]; then /bin/echo "'TargetUser' is empty. You must specify a user!" exit 1 fi # Verify the TargetUser is valid if /usr/bin/dscl . -read "/Users/${TargetUser}" 2>&1 >/dev/null; then /bin/echo "Validated ${TargetUser}" else /bin/echo "Specified user \\"${TargetUser}\\" is invalid" exit 1 fi # Install Homebrew | strip out all interactive prompts /bin/bash -c "$(curl -fsSL \\ https://raw.githubusercontent.com/Homebrew/install/master/install.sh | \\ sed "s/abort \\"Don't run this as root\\!\\"/\\ echo \\"WARNING: Running as root...\\"/" | \\ sed 's/ wait_for_user/ :/')" 2>&1 | tee "${BREW_INSTALL_LOG}" # Reset Homebrew permissions for target user brew_file_paths=$(sed '1,/==> This script will install:/d;/==> /,$d' \\ "${BREW_INSTALL_LOG}") brew_dir_paths=$(sed '1,/==> The following new directories/d;/==> /,$d' \\ "${BREW_INSTALL_LOG}") # Get the paths for the installed brew binary brew_bin=$(echo "${brew_file_paths}" | grep "/bin/brew") brew_bin_path=${brew_bin%/brew} # shellcheck disable=SC2086 chown -R "${TargetUser}":admin ${brew_file_paths} ${brew_dir_paths} chgrp admin ${brew_bin_path}/ chmod g+w ${brew_bin_path} # Unset home/user environment variables unset HOME unset USER # Finish up Homebrew install as target user su - "${TargetUser}" -c "${brew_bin} update --force" # Run cleanup before checking in with the doctor su - "${TargetUser}" -c "${brew_bin} cleanup" sleep 1 currentuser=`stat -f "%Su" /dev/console` chown -R $currentuser /usr/local/lib exit 0
Then I have added it to the policy and in the Files and Processes > Execute Command, included this command:
thisUser=`stat -f '%u %Su' /dev/console | awk '{ print $2 }'`;su "$thisUser" -c "brew install jq"
This fully installs jq and JSON parsing with jq will work on that mac.
I suggest to trigger it at Enrollment Complete.
Also, if you need to implement this towards the macs in production, I did it this way:
2 extension attributes: 1 for brew presence and 1 for jq presence, 2 smart groups: Group 1 checks if brew is not installed on the mac, which is then scoped to a policy which pushes brew + jq to the affected mac, Group 2 checks if mac has brew present, but jq missing, which is then scoped to a policy which pushes only jq to the afected mac
Here are the 2 Computer Extension Attributes:
1) Brew presence check:
#!/bin/bash if [ ! -z $(which brew) ];then echo "<result>Brew installed</result>" else echo "<result>Brew Not installed</result>" fi exit 0
2) jq presence check:
#!/bin/bash if [ ! -z $(which jq) ];then echo "<result>jq installed</result>" else echo "<result>jq Not installed</result>" fi exit 0
Maybe not the best or cleanest solutions, but it works 🙂
sdagley
  • September 24, 2021
@akamenev47 Are you sure what you packaged is a jq executable? You might also try just packaging the jq-osx-amd64 executable from the jq homepage: https://github.com/stedolan/jq/releases/download/jq-1.6/jq-osx-amd64 You can also put the binary in a directory other than /usr/local/bin and use the full path to it in your script.
akamenev47
not sure, that's the thing 🙂
https://github.com/stedolan/jq/releases/download/jq-1.6/jq-osx-amd64  - I have seen this one, but unsure how can I "install" it or implement it for jq to work?
akamenev47
  • September 25, 2021
sdagley
  • September 30, 2021
@akamenev47 You don't need to "install" it, it's an executable binary. You just need the downloaded binary on the target Mac, with the executable flag set, and your script adjusted to call the binary by the full path
akamenev47
  • October 9, 2021
I have modified the brew installation script, so now it will install brew and jq within 1 single script. You can find it here: https://gist.github.com/shurkin18/62ec34967794a32f9d63615db881ab5c
sdagley
  • October 9, 2021
@akamenev47 Installing brew just to get jq seems like overkill, and is your security org ok with brew being installed in your environment? (if they want LAPS it seems likely like they'd have issues with brew). The https://github.com/stedolan/jq/releases/download/jq-1.6/jq-osx-amd64 link in my earlier message is for the Mac executable version of the jq binary. Just download it, put it in a location that your script can reference (e.g. /Library/Application Support/MyOrg), package it with Composer, and deploy that package to your Macs.
akamenev47
  • October 10, 2021
Hmm, well engineers all have brew installed, otherwise everyone is admin and can install it themselves, is brew such a great security issue?
sdagley
  • October 11, 2021
@akamenev47 Do you have any sort of security or software standards approval process for software installed on Macs at your org, or are users free to install anything they want? If the answer to the former is yes then the several thousand apps that can be installed by brew casks might be an area of contention for your security & software standards groups
