Failed Commands - Invalid status code
  • June 23, 2022
  • 290 views
Good morning all
I'm newish to Jamf so bare with me if this is obvious.  Today I started prepping 2 new computers, one was pre-enrolled brand new out of the box and the other was an older MBA that I used a manual invite.
Most of the usual policies applied except for 3, the same 3 on both systems.  When I check Inventory -> Management for the devices, they appear in the "Failed Commands"  section with an "Invalid Status Code" listed as the status.  I have tried removing these computer from the policy scopes, cancelling the commands and then re-adding them to the scopes.  Same result.
Does anyone have any suggestions?  I don't know why all of sudden these are 3 (specifically) are failing.  They have worked for months, and I have not made any changes to them.
Thanks
Best answer by junjishimazaki
Have you tried running the following commands: sudo jamf manage
If that completes, run sudo jamf recon, then once that completes, then run sudo jamf policy
junjishimazaki
  • June 23, 2022
  • June 23, 2022
Seems to have done the trick!  Thanks very much!
junjishimazaki
You're welcome, I'm glad that solved the problem.
