Getting Error Pushing Intel Mac OS to Monterey via Self Service
  • October 3, 2022
  • 4 replies
  • 29 views
Hi All,
Sorry if this has been asked before.
I'm using this script with zero modifications except for the parameter changes as shown in screen shots below:
https://github.com/kc9wwh/macOSUpgrade/blob/master/macOSUpgrade.sh
I pulled the installer for 12.6 from Mr. Macintosh. The installer will attempt download from self service but I get this error: We were unable to prepare your Computer for OS Monterey.
Best answer by sdagley
@EUC-Admin The macOSUpgrade script hasn't ben updated in a while. The more common script these days is https://github.com/grahampugh/erase-install (ignore the name, it does updates as well). There is a section in the Wiki on how to use with Jamf Pro: https://github.com/grahampugh/erase-install/wiki/8.-Use-in-Jamf-Pro
sdagley
  • October 3, 2022
  • October 3, 2022
Hey! Thanks for the reply I'll give this script a shot.
# Pulls the current logged in user and their UID
currUser=$(ls -l /dev/console | awk '{print $3}')
currUserUID=$(id -u "$currUser")
fvPass=$(
# Prompts the user to input their FileVault password using Applescript. This password is used for a SecureToken into the startosinstall.
/bin/launchctl asuser "$currUserUID" sudo -iu "$currUser" /usr/bin/osascript <<APPLESCRIPT
set validatedPass to false
repeat while (validatedPass = false)
	-- Prompt the user to enter their filevault password
	display dialog "Enter your macOS password to start the macOS upgrade" with icon file "System:Library:CoreServices:CoreTypes.bundle:Contents:Resources:FileVaultIcon.icns" default answer "" buttons {"Continue"} default button "Continue" with text and hidden answer
	set fvPass to (text returned of result)
	display dialog "Re-enter your macOS password to verify it was entered correctly" buttons {"Continue"} with icon file "System:Library:CoreServices:CoreTypes.bundle:Contents:Resources:FileVaultIcon.icns" default answer "" default button "Continue" with text and hidden answer
	if text returned of result is equal to fvPass then
		set validatedPass to true
		fvPass
		display dialog "The passwords you have entered do not match. Please enter matching passwords." with title "FileVault Password Validation Failed" buttons {"Re-Enter Password"} default button "Re-Enter Password" with icon file "System:Library:CoreServices:CoreTypes.bundle:Contents:Resources:FileVaultIcon.icns"
	end if
end repeat
AppleScript
##Heading to be used for jamfHelper
heading="Please wait as we prepare your computer for macOS Monterey..."
##Title to be used for jamfHelper
description="
This process will take approximately 20-30 minutes.
Once completed your computer will reboot and begin the upgrade which can take an additional 15-20 minutes."
##Icon to be used for jamfHelper
icon=/Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/InstallAssistant.icns
##Launch jamfHelper
/Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType fs -title "" -icon "$icon" -heading "$heading" -description "$description" &
jamfHelperPID=$!
##Start macOS Upgrade
echo $fvPass | /Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/startosinstall --agreetolicense --forcequitapps --nointeraction --user $currUser --stdinpass --pidtosignal $jamfHelperPID >> /var/log/startosinstall.log 2>&1 &
Appreciate the insight. I'm trying the above now and it seems to be going somewhere.
If it breaks anything I'm trying what you suggest as a follow up.
  • October 3, 2022
@sdagley would it make sense to bundle these within the same policy or separate the two.
One policy to pull down the installer while the other executes the erase to install via self service?
  • October 10, 2022
Highly recommend following the process recommended by @sdagley it works cleanly as well as on M1 Apple devices as well.
I will say that on the M1 it still asks for a password but you do not need admin its just the end users account.
