macOS Ventura - Jamf 10.42.0 - Network settings
  • October 25, 2022
  • 12 views
RobinJJ
DNS Proxy
Our DNS settings in Jamf are set to "Restricted" to not allow users to disable it. This is overwritten in macOS Ventura as the user can disable it.
Firewall settings
This field is "greyed out" on macOS Ventura. (Both disable option and "Options..." option. Looks like you need to unlock the setting with the "Lock" icon, which isn't present in Ventura.
1 reply
Is there any update ?
