Unable to run MacOS Ventura update on M1 Macs only
  • November 15, 2022
  • 48 replies
  • 271 views
We have about 50/50 M1 vs Intel chip Macbooks.
We are using Jamf Connect as well (not sure if relevant)
We have a standard Admin account created and loaded for every computer during prestage enrollment.
We are not able to run the MacOS Ventura Installer on the M1 macs because it does accept the Admin credentials provided. These same Admin credentials are working for installing apps, etc. The update does work if you switch to the mentioned Admin account on the computer and then run the update.
The update has none of these issues for the Intel macs. I can run the update from the user's account using the same Admin credentials.
Anyone know why the M1 would not let us run this update from the user's standard account, even providing the correct Admin credentials?
Best answer by bcrockett
Apple Business support told me that it's not possible to update to Ventura from the Standard account and that we would have to switch to the Admin account to run the update for these M1 devices...
Ya, this film showing my configuration to force stander accounts to update proves it is possible to update from Monterey to Ventura on a stander user's account.
They can self-initiate as well with this configuration.
So far I have had over 100 m1 client computers in the standard user account category update to Ventura successfully.
Hope that helps. ~ B
AtillaTheC
  • November 15, 2022
we use https://github.com/grahampugh/erase-install/wiki for our in place upgrades. Essentially that admin account would not have the correct secure token for an OS upgrade.
  • November 15, 2022
I have the erase install workflow set up and it works like a charm on M1 when users self-initiate.
Users read this document to learn how to update:
https://docs.google.com/document/d/1sC0BnvzptHWkEzscmbWnugUrKnBoxzDVlj0bnEeJhcw/edit#
Then run the policy via self-service.
However, I am wondering if there is a good way to Prompt users to Install an item made available in Self Service such as the erase-install (update) policy?
Basically, nudge but instead of promoting the user to update from system preferences which they can not do for major updates because they do not have admin rights. Instead, prompt users to run the erase-install (update) policy. Which then prompts them for their password from a token account and allows the update to run.
AtillaTheC
  • November 16, 2022
https://github.com/bartreardon/swiftDialog
  • November 16, 2022
@AtillaTheC
Thanks for sharing that resource!
I used it to solve my problem in the following way.
1. I downloaded the .pkg from the swiftDialog repo on git hub. Then uploaded it to the JSS
2. I copied and pasted the example Jamf Scripts into my jss.
3. I created a policy that:
a. installs the swiftDialog box on the client's computer
b. Runs the dialog script with the following parameters:
The client sees a dialog box that says update now. They click update and the
a terminal command is executed which runs that erases install workflow for updating the computer.
This prompts the M1 standard users without admin rights to enter their login password for their token volume and the update starts!
It is not as clean as nudge but functional.
Victory! ~ B
  • November 17, 2022
  • November 17, 2022
AtillaTheC
  • November 17, 2022
Correct, using the erase-install github will work as long as the user account has a secure token
  • November 17, 2022
Erase/install requires the Mac to be backed up in Time Machine correct?
  • November 17, 2022
Good question.
Where did you learn about that requirement?
AtillaTheC
  • November 17, 2022
no, you can use the --reinstall command instead of the --erase one. See the JAMF wiki in the repo
  • December 5, 2022
This worked for me. Thank you much!
  • December 7, 2022
I am unable to get password authorization. while doing ventura update with following script via self service
softwareupdate --list-full-installers | grep 'macOS' | awk '{print ++count " " $0}'
softwareupdate --fetch-full-installer
softwareupdate --fetch-full-installer --full-installer-version 13.0.1
echo $pass | '/Applications/Install macOS Ventura.app/Contents/Resources/startosinstall' --user $admin --stdinpass --agreetolicense --nointeraction --forcequitapp
Install finished successfully Error: failed to authorize for installation. Provide a password with --stdinpass or --passprompt. By using the agreetolicense option, you are agreeing that you have run this tool with the license only option and have read and agreed to the terms. If you do not agree, press CTRL-C and cancel this process immediately.
AtillaTheC
  • December 7, 2022
If you are really dead-set against using the eraseinstall script thats known to work you can try to adapt this old script I used for Monterey.
Honestly tho, erase-install script is the best surefire way to get this done.
#!/bin/bash # Pulls the current logged in user and their UID currUser=$(ls -l /dev/console | awk '{print $3}') currUserUID=$(id -u "$currUser") fvPass=$( # Prompts the user to input their FileVault password using Applescript. This password is used for a SecureToken into the startosinstall. /bin/launchctl asuser "$currUserUID" sudo -iu "$currUser" /usr/bin/osascript <<APPLESCRIPT set validatedPass to false repeat while (validatedPass = false) -- Prompt the user to enter their filevault password display dialog "Enter your macOS password to start the macOS upgrade" with icon file "System:Library:CoreServices:CoreTypes.bundle:Contents:Resources:FileVaultIcon.icns" default answer "" buttons {"Continue"} default button "Continue" with text and hidden answer set fvPass to (text returned of result) display dialog "Re-enter your macOS password to verify it was entered correctly" buttons {"Continue"} with icon file "System:Library:CoreServices:CoreTypes.bundle:Contents:Resources:FileVaultIcon.icns" default answer "" default button "Continue" with text and hidden answer if text returned of result is equal to fvPass then set validatedPass to true fvPass else display dialog "The passwords you have entered do not match. Please enter matching passwords." with title "FileVault Password Validation Failed" buttons {"Re-Enter Password"} default button "Re-Enter Password" with icon file "System:Library:CoreServices:CoreTypes.bundle:Contents:Resources:FileVaultIcon.icns" end if end repeat AppleScript ) ##Heading to be used for jamfHelper heading="Please wait as we prepare your computer for macOS Monterey..." ##Title to be used for jamfHelper description=" This process will take approximately 20-30 minutes. Once completed your computer will reboot and begin the upgrade which can take an additional 15-20 minutes." ##Icon to be used for jamfHelper icon=/Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/InstallAssistant.icns ##Launch jamfHelper /Library/Application\\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType fs -title "" -icon "$icon" -heading "$heading" -description "$description" & jamfHelperPID=$! ##Start macOS Upgrade echo $fvPass | /Applications/Install\\ macOS\\ Monterey.app/Contents/Resources/startosinstall --agreetolicense --forcequitapps --nointeraction --user $currUser --stdinpass --pidtosignal $jamfHelperPID >> /var/log/startosinstall.log 2>&1 & exit 0
  • December 7, 2022
"failed to authorize for installation"
did you adjust the script to allow for authorization from both an admin account and volume owner?
  • December 7, 2022
I believe no. can you please guide me how to achieve this
  • December 7, 2022
I can try. Can you write out your current configuration with annotated screenshots that show the setting in your JSS?
  • December 8, 2022
Hi, I have used erase-installer 27.1 package and erase-installer-launcher script downloaded from github. passed the following arguments. as per screen shot pasted below with user name and password of admin.
But getting error 'this account cannot be used for mac os reinstall' tried with another local admin as well. same result. can you please anyone suggest to bypass this. i want to upgrade os without asking admin password for end users from self service who are all having standard user accounts on the devices for login
AtillaTheC
  • December 8, 2022
the first account created on the machine, likely the end user, would have the proper privs, regardless of admin, to us their user/password.
  • December 8, 2022
Write out the full sequence of your test configuration step by step. The bug in your configuration is in one part of the sequence of operations. However, if you do not write them out, I can not review and help debug them effectively.
  • December 8, 2022
I have tried with two scenarios.
1. with simple script attached to the policy - scoped to test devices
script used: ''#!/bin/bash softwareupdate --list-full-installers | grep 'macOS' | awk '{print ++count " " $0}' softwareupdate --list-full-installers softwareupdate --fetch-full-installer softwareupdate --fetch-full-installer --full-installer-version 13.0.1 echo $Pass | '/Applications/Install macOS Ventura.app/Contents/Resources/startosinstall' --user $admin --stdinpass --agreetolicense --nointeraction --forcequitapps Result: Install finished successfully Error: failed to authorize for installation. Provide a password with --stdinpass or --passprompt. By using the agreetolicense option, you are agreeing that you have run this tool with the license only option and have read and agreed to the terms. If you do not agree, press CTRL-C and cancel this process immediately. /Library/Application Support/JAMF/tmp/MacOSUpgrade.sh test 2: line 7: syntax error near unexpected token `|'
2. Tried with erase-installer packgae 27.1 depnotify and erase-installer-laucher.sh script with the following argument parameters (screenshot pasted)
Result: 'This account can not be user for reinstall mac os' error screen
  • December 8, 2022
Also tried with erase installer package with policy and the following execute command in files and processes tab
  • December 8, 2022
using jamf pro 10.42.1 and testing in M1 mac mini device
  • December 8, 2022
hope i have provided the informations required. if you need any additional info please revert. i can check and provide
  • December 8, 2022
Let's try a different approach. No script this time.
Clone the workflow in this film on your test device. Except trigger it from self-service.
Let me know if that works.
  • December 11, 2022
@bravichandran I created some new resources to try and help you automate the process of implementing the major update from macOS Monterey to Ventura:
1.  Configure erase - install to trigger the update from self-service using this workflow.    Once that is done email users and let them know they can and should start updating from self-service . This is the best option IMO for user accounts that are standard. I your users have admin accounts there are more options.
2. Next you can use a simple pop-up box that tells the user they must update which has an action button that when pressed will - triggers the self-service policy above. Link to this workflow here.  Once that is in production for two weeks or so it should work for ~50-70% of your users. *make sure to inventory update often for these non-updated users so they are excluded from the smart group of computers that have not been updated.
3. For the last ~ 30% configure nudge to prompt the user to update. Make sure, it also triggers the policy step one. This is the link to the workflow.   ( this demo config is ugly however, it is functional)
