MacOS Ventura Volume Disk Authorization
  • June 9, 2023
  • 95 views
Hello,
I'm having a standard user upgrade their OS from Big Sur to Ventura through system preferences. They are Volume disk owners and secure token is enabled. Also, I installed bootstrap token to be on the safe side. The endpoint is a MacBook air M1. However, they get the "You must provide authorization for this volume by setting it as your startup disk. You can relaunch the installer after authorization has been provided."
Troubleshoot steps are taken:
- Checked user is a VO and secure token is enabled
- Check there is only one disk and selected to use as the default start up disk.
- Deleted the installer and downloaded again
The only workaround solution I found is to log into the admin account and update the OS from there but this is not feasible. Any suggestions?
1 reply
pkleiber
  • June 13, 2023
