Self Service Push Notifications
  • July 14, 2023
  • 100 views
Sorry if this is a really silly question, but...
On https://www.jamf.com/blog/jamf-supports-rapid-security-response/ it states:
Organizations can use Jamf Pro to send push notifications via Self Service to encourage users to apply the Apple Rapid Security Response, and with the combination of settings to permit users to apply Rapid Security Response updates and lightning-fast reporting on current update status, Jamf admins are empowered to protect their fleets from emerging threats as soon as Apple identifies them.
Does anyone have an example or guide on how one might do that?
mvu
Forum|alt.badge.img+22
  • July 14, 2023
Usually send push notifications via Self Service for iOS devices.
1. Click Devices tab
2. Select your Smart Group or Static Group
3. Click View (Bottom-left)
4. Click Action
5. Select "Send a Notification to Mobile Devices with Jamf Self Service for iOS Installed"
6. Click Next
7. Enter you Subject and message
8. Click Next (This sends the notification)
  • July 14, 2023
4. Click Action
6. Click Next
Thank you @mvu. Does this only work for mobile devices or is there a way to do this for 'Computer' objects too?
