Deploy CrowdStrike agent on iOS through Jamf Pro - URGENT!!!
  • August 24, 2023
  • 584 views
I am trying to install CrowdStrike agent on an iPhone (iOS) but keep running into errors.
Steps taken:
1. CrowdStrike app is pushed out to iOS via 'Mobile Device Apps' + Managed Distribution - Successful
2. Created a configuration profile for mobile devices. Content Filter payload configured.
Filter Type - Plugin
Identifier - com.crowdstrike.falconmobile
Filter WebKit - Unchecked
Filter Socket - Checked
Under Custom data, I have key/value mapping I got from CrowdStrike that contains the following key/value pairs:
user_email$EMAIL
hostname$SERIALNUMBER
skip_legalTrue
cloud_id<REDACTED>
customer_id<REDACTED>
provisioning_token<REDACTED>
The application installs but when I open the application and click "Get Started" I see the following error - Crowdstrike missing deploymeny profile ios. Content Profile does not exist.
Can someone help?
  • April 19, 2024
Was this ever resolved? We would like to do the same.
Thanks
Bobby
  • August 30, 2024
Thanks
Bobby
I was able get Crowdstrike app working on an ipad through JAMF.  The information that kabiradvani posted was a starting point but I needed to add in a few items for the Crowdstrike app to successfully and transparently active our JAMF managed ipads.
Steps taken:
1. CrowdStrike app is pushed out to iOS via 'Mobile Device Apps' + Managed Distribution; Device level and install immediately
2a. Content Filter
  • Filter Name: CrowdStrike Falcon
  • Filter Type: Plugin
  • Identifier: com.crowdstrike.falconmobile
  • Organization: <information from your Security team managing the Crowdstrike subscription>
  • Socket Filter: Enabled
  • Under Custom data, key/value mapping I got from the mobile config file our Security team generated from the Crowdstrike subscription, contains the following key/value pairs:
user_email$EMAIL
hostname$DEVICENAME
skip_legalTrue
cloud_id<REDACTED>
mdm_device_id<REDACTED>
grouping_tags<REDACTED>
2b. Notifications
  • CrowdStrike Falcon + Bundle ID: com.crowdstrike.falconmobile
  • Apple generic + Bundle ID: com.apple.notificationsettings.<REDACTED>
  • Generic Apple + Bundle ID: com.apple.notificationsettings
