How to re-deploy Jamf Self Service app on iOS
  • November 7, 2023
  • 8 replies
  • 183 views
Our Jamf Pro managed iPads are setup to only have Jamf Self Service deployed, not the app store.
The Jamf Self Service-app had the setting "Allow users to remove app (iOS 14 or later)" enabled, and some user removed the app. Is it possible to redepoy the app to the iPad, or do I have to wipe the device to do this?
(I unchecked the "Allow users to remove app")
Best answer by joshuasee
Simpler: Exclude the affected device from the Self Service Mobile deployment, save to newly assigned only, remove the exclusion, and save again to newly assigned. The install command will go out to the device again.
sayr01
  • November 7, 2023
You should be able to redeploy the app.  no need to wipe the device.
  • November 7, 2023
That's good to hear. But how? The scope of the app is "all devices" and "all users". How do I get the app back?
  • November 7, 2023
An inventory update should reinstall the app. Is that not what you're seeing?
  • November 7, 2023
Nope. Inventory update didn't do a thing.
I've wiped the device now, so l call it a day. Thanks for the help all...
Steven_Xu
  • November 8, 2023
remove all devices and users from the scope will uninstall this app, save and wait for a while. and then add the device to the scope again, the app will be reinstalled.
by the way, target to the devices is fine, you don't need to add users to the scope.
  • November 9, 2023
  • November 13, 2023
That's clever! I'll use this next time.
So other users won't be affected.
  • November 17, 2023
If for whatever reason that doesn't work, also know that nothing is stopping you from creating an additional instance of the app using the same license pool, but different scoping.
