Software Update - Authentication is Disabled
  • November 28, 2023
  • 5 replies
  • 1914 views
dlondon
Just wondering if anyone has seen this.
 The machine is Ventura (Mac OS 13.6) and trying to upgrade to Mac OS 14.1
Machine is bound to an AD domain and the user has a secure token and is an administrator on the machine.  The user is logged on with a domain account i.e. a mobile account.  The machine is an M1
I tried forcing the update/upgrade via Jamf using the MDM framework from the server as they are overseas but it got to the end of preparing and prompted them again
Best answer by dlondon
Sorry, I did get a solution to this.  It’s not always enough to enable the Secure Token.  The secure token can have a password that is different to the logon password.  For example if you have Microsoft AD bound Mac’s and change the user passwords on a system that is not the Mac’s i.e. a special server for password changes.  Mac OS doesn’t play well with that method of changing the password when it comes to Secure Tokens.  When the password is changed externally, the Secure Token will still have the previous password.  This behaviour is different for keychains - in that case the machine recognises the password change at next logon and prompts for the old password, then changes the logon keychain password to be the new logon password.  Unfortunately the same thing is not done for Secure Token hence it prompts when trying to do something like run updates that requires a Secure Token as the Secure Token password is now different to the logon password.
The only way out is if you have another account on the machine that has a valid secure token and the password is known.  You can use that in conjunction with the user who must enter their new password.
This is the script I’ve developed and it runs via a Self Service policy
# refreshSecureToken.bash
# some ideas from suggestion by Mauricio Pellizzon https://www.jamf.com/jamf-nation/discussions/32795/script-best-way-to-request-user-input
# and brunerd in https://www.jamf.com/jamf-nation/discussions/31837/jamf-wants-access-to-control-system-events
# other snippets from all over
# ChatGPT not employed
# Purpose: To solve the issue with AD binding, Mobile Accounts and Secure Tokens not being synced with new password when user changes password via external system
# David London
# 2023-12-12
admin=$4
adminpassword=$5
iconFile="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/Resources/Message.png"
Message() {
/Library/Application\ Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper -windowType utility -icon "$iconFile" -title "University IT" -heading "$1" -description "$2" -button1 "OK"
userName=$(ls -la /dev/console | cut -d " " -f 4)
user_entry=""
validateResponce() {
case "$user_entry" in
"noinput" ) echo "empty input" & askInput ;;
"cancelled" ) echo "time out/cancelled" & exit 1 ;;
* ) #echo "$user_entry" ;;
esac
askInput() {
user_entry=$(sudo -u "$userName" osascript <<EOF
use AppleScript version "2.4" -- Yosemite (10.10) or later
use scripting additions
set theTextReturned to "nil"
try
set theResponse to display dialog "Please enter your login password" with title "Get User Login Password" buttons "Save" default button "Save" default answer "" with hidden answer
set theTextReturned to the text returned of theResponse
end try
if theTextReturned is "nil" then
return "cancelled"
else if theTextReturned is "" then
return "noinput"
return theTextReturned
end if
EOF
validateResponce "$user_entry"
# Check that the admin account passed as $4 is an account on the machine
adminExists=$(dscl . -list /Users 2>&1 |grep "$4")
if [[ -z $adminExists ]]; then
Message "Error" "The admin user $4 passed in by the management system does not exist on your computer so exiting.
Please contact the IT Service Desk on PHONE NUMBER HERE and report the problem."
exit 2
echo "The admin user $4 exists on the system so continuing"
# check the admin account has a secure token
# Potentially comment this out as the script will add a secure token
adminSecureTokenStatus=$(sysadminctl -secureTokenStatus "$4" 2>&1 | grep ENABLED)
if [ -z "$adminSecureTokenStatus" ]; then
Message "Error" "It looks like the user $4 does NOT have a secure token.
exit 2
echo "$4 has a secure token so continuing"
# Check the user is an admin
if id -Gn "$userName" | grep -q -w admin; then
echo "User $userName is an admin so continuing";
Message "Error" "It looks like you are not an Administrator so this won't help.
exit 2
# get the user password
valid="xx"
while [ -n "$valid" ]
do
askInput "$userName"
valid=$(dscl /Local/Default -authonly $userName "$user_entry")
if [[ -n "$valid" ]]; then
# display pop up if wrong password here
Message "Oops" "It looks like you mistyped your password, please try again"
done
# now use the password from the user ...
echo "Turning OFF Secure Token for $userName"
sysadminctl -secureTokenOff "$userName" -password "$user_entry" -adminUser "$admin" -adminPassword "$adminpassword"
# check the secure token status of the user
sysadminctl -secureTokenStatus "$userName"
echo "Turning ON Secure Token for $userName"
sysadminctl -secureTokenOn "$userName" -password "$user_entry" -adminUser "$admin" -adminPassword "$adminpassword"
Below post can help you. Since authentication is not failed but disabled which might be due to issue with secure token.
https://community.jamf.com/t5/jamf-pro/softwareupdate-is-trying-to-authenticate-user-authentication-is/m-p/245357
sdagley
  • November 28, 2023
@dlondon If send the update command with a user deferral option it'll always prompt for credentials. Use the option to download and install immediately to perform the update without user prompting. You might also want to have the user restart that Mac if it's been up more than 7 days as that seems to be the threshold (at least in my environment) when macOS Ventura starts to have issues with the MDM pushed update command.
dlondon
  • December 7, 2023
Thanks @sdagley and @user-rLcbGKzEGV the user is overseas and has been out of contact since I asked them to check a few things for me.
I'm going down the secure token rabbit hole to see if setting it off and then back on will have any effect.
Steve - I did try the MDM command via Jamf and install immediately without prompting but nothing happened.  I will check on the restart before doing the update comment to see if that helps.
  • January 16, 2024
I have tried Re-enabling the Secure Token.
Still the error is same
Kindly help on the same
Thank you
dlondon
  • January 13, 2026
# David London
# 2023-12-12
admin=$4
adminpassword=$5
Message() {
user_entry=""
esac
askInput() {
try
end try
return "cancelled"
return "noinput"
end if
EOF
exit 2
exit 2
exit 2
valid="xx"
do
done
