Sonoma, JAMF 11.2 and updates
  • February 8, 2024
  • 8 replies
  • 75 views
MMTechno
Hi everyone,
i can for the life of me work out how to efficiently deploy updates to my devices. I have been testing with Sonoma 14.0 as a baseline and JAMF 11.2 in the lab.
What i want to achieve is deploy an update and allow the end user to defer it by a number of days. I have tested deploying an update and installing immediately and it works.
In JAMF, Computers > Software Updates > i can target a group with the option : Download, install, and allow deferral
and i can specify a number. Apparently these are the deferrals i can allow the user. How do i specify the days i want the user to be able to defer? Do i need a config profile?
Is software updates solely from JAMF really achievable ? I think i am wasting my time here. Will Nudge or any other script help with that? I am at my wits end with how updates work on Macs.
Any insights would be appreciated.
Best answer by DBrowning
Thanks for letting me know.
If i use the option to  Download, install, and allow deferral will i be able to use Nudge as well to point the user to the right direction ? I assume that deferral means days right?
Apart from that, do i need to deploy any configuration profiles to the devices for any other update settings?
@MMTechno deferral means how many times they can defer it.  If you set it to 3, macOS should prompt them 3 times and on the 4th it will install the update.  This does work out to be days as the MDM command repeats every 24 hours.
AJPinto
  • February 8, 2024
There is currently a bug in Jamf that is not expected to be fixed until after 11.3. Make sure you are telling the devices to install the latest available update and not specifying a version. Jamf bug aside, managing updates on macOS is a nightmare even with Declarative Device Management due to how poorly the workflow apple has designed functions.
PI116287 "Scheduled Software Updates (DDM) using Specific Versions Does Not Work"
MMTechno
  • February 8, 2024
tdenton
  • February 8, 2024
You need super https://github.com/Macjutsu/super had some great sucess with it for major OSX upgrades Its what we will be using for our lab upgrades from Ventura to Sonoma.
https://www.youtube.com/watch?v=Lj26nuCH1jA
DBrowning
  • February 8, 2024
MMTechno
  • February 8, 2024
Thanks for clarifying that!
MMTechno
  • February 11, 2024
Thanks for letting me know. Currently investigating what is the best method of doing this.. I guess i have 3 options.. Use the out of the box option in Jamf 11.2 or choose between Nudge and super
MMTechno
  • February 11, 2024
Currently looking into that.
How easy / hard is for super to be set up?
tdenton
  • February 15, 2024
Straightforward if you follow the wiki they provide
