Microsoft Teams (Work or School) removal script
  • March 13, 2024
  • 9 replies
  • 434 views
mojo21221
Hey all, I have been using the tools at https://office-reset.com/macadmins/ for assisting with O365 and other office related issue. However, I was wondering if anyone has made a Microsoft Teams (Work or School) removal script? Office reset has a full office removal script, however it does not include he new Teams as part of the removal...  Main reason for wanting it is to get the mac back to a clean slate from the O365 perspective to troubleshoot some other issues.
AJPinto
  • March 13, 2024
We are just going to remove the Teams app with rm. Microsoft does not provide an uninstaller, you could use the office removal tool, but with Teams cleanup it should not be needed.
sudo rm -rf "/Applications/Microsoft Teams.app"
mojo21221
  • March 13, 2024
Thanks for the quick response AJ. I agree the office removal tool does a great job on removing Teams classic. However, I am looking to remove the new Microsoft Teams (Work or School). It looks like MS has made new locations for the behind the scenes files that make it work... Hence seeing if anyone has made a script. I tried dropping it into AppCleaner and seeing what files it finds, but wasnt sure if there are even more to remove...
pete_c
  • March 13, 2024
Try this:
#!/bin/bash autoload is-at-least APP_NAME="Microsoft Teams (work or school)" GetLoggedInUser() { LOGGEDIN=$(/bin/echo "show State:/Users/ConsoleUser" | /usr/sbin/scutil | /usr/bin/awk '/Name :/&&!/loginwindow/{print $3}') if [ "$LOGGEDIN" = "" ]; then echo "$USER" else echo "$LOGGEDIN" fi } SetHomeFolder() { HOME=$(dscl . read /Users/"$1" NFSHomeDirectory | cut -d ':' -f2 | cut -d ' ' -f2) if [ "$HOME" = "" ]; then if [ -d "/Users/$1" ]; then HOME="/Users/$1" else HOME=$(eval echo "~$1") fi fi } ## Main LoggedInUser=$(GetLoggedInUser) SetHomeFolder "$LoggedInUser" echo "Office-Reset: Running as: $LoggedInUser; Home Folder: $HOME" /usr/bin/pkill -9 "${APP_NAME}" /usr/bin/pkill -9 'Microsoft Teams Webview Helper' echo "Office-Reset: Removing configuration data for ${APP_NAME}" /bin/rm -rf "$HOME/Library/Application Scripts/com.microsoft.teams2" /bin/rm -rf "$HOME/Library/Application Scripts/com.microsoft.teams2.launcher" /bin/rm -rf "$HOME/Library/Application Scripts/com.microsoft.teams2.notificationcenter" /bin/rm -rf "$HOME/Library/Containers/Microsoft Teams (work or school)" /bin/rm -rf "$HOME/Library/Containers/Microsoft Teams Launcher" /bin/rm -rf "$HOME/Library/Containers/com.microsoft.teams2.notificationcenter" /bin/rm -rf "$HOME/Library/Group Containers/UBF8T346G9.com.microsoft.oneauth" /bin/rm -rf "$HOME/Library/Group Containers/UBF8T346G9.com.microsoft.teams" /bin/rm -rf "$HOME/Library/Preferences/com.microsoft.teams2.helper.pliszt" /bin/rm -rf "$HOME/Library/Saved Application State/com.microsoft.teams2.savedState" /bin/rm -rf "$HOME/Library/Saved Application State/com.microsoft.teams2.savedState" KeychainHasLogin=$(/usr/bin/sudo -u "$LoggedInUser" /usr/bin/security list-keychains | grep 'login.keychain') if [ "$KeychainHasLogin" = "" ]; then echo "Office-Reset: Adding user login keychain to list" /usr/bin/sudo -u "$LoggedInUser" /usr/bin/security list-keychains -s "$HOME/Library/Keychains/login.keychain-db" fi echo "Display list-keychains for logged-in user" /usr/bin/sudo -u "$LoggedInUser" /usr/bin/security list-keychains /usr/bin/sudo -u "$LoggedInUser" /usr/bin/security delete-generic-password -l 'Microsoft Teams Identities Cache' /usr/bin/sudo -u "$LoggedInUser" /usr/bin/security delete-generic-password -l 'com.microsoft.teams.HockeySDK' /usr/bin/sudo -u "$LoggedInUser" /usr/bin/security delete-generic-password -l 'com.microsoft.teams.helper.HockeySDK' exit 0
pete_c
  • March 13, 2024
Try this:
Remember that Jamf runs scripts as root, which the MS docs sort of neglect to mention.
sdagley
  • March 13, 2024
@mojo21221 Paul Bowden, who works for Microsoft but created the Office-Reset site on his own, is out on medical leave, and he's not updating that site or the MacAdmins.software site he also created. He did however post a 2.0 Beta 1 version of the main removal tool (https://office-reset.com/download/Microsoft_Office_Reset_2.0.0.pkg) before going out and if you use a tool like Suspicious Package you can examine the various postinstall scripts in that package to see how they work, including the one updated for Microsoft Teams (Work or School).
alpaul
  • June 7, 2024
Team,
You can download the New Microsoft Teams application package from below link.
https://www.microsoft.com/en-us/microsoft-teams/download-app
DMH2000
  • June 25, 2024
@mojo21221 Re: and he's not updating that site or the MacAdmins.software site.  Remember even though the page isn't updated you will get the latest version when downloading.
pete_c
  • March 11, 2025
https://github.com/cocopuff2u/MOFA/tree/main
  • March 14, 2025
@pete_c Thank you for providing the link to a fantastic source :-)
