Can't bind a Mac. Node name not found (-2000), "Unknown Authentication Method."
  • March 2, 2016
  • 56 views
bradtchapman
Forum|alt.badge.img+20
I have a Mac that will not bind, and I'm at a loss to explain why. Maybe @arekdreyer or some other AD expert can offer some insight. Every AD server in our forest turned it away.
  • Mac uptime is 5 days;
  • Mac OS X 10.8.5;
  • Network configuration is correct;
  • Computer is managed in JSS;
  • Mac's clock is accurate and time server is reachable;
  • ComputerName, HostName, LocalHostName all match;
  • Computer record has been removed from AD;
  • dsconfigad says node name not found (-2000).
I set opendirectoryd logging to "info" level (odutil set log info). This is what I got; the company name has been altered, obviously.
2016-03-03 06:44:10.308083 CST - 14659.243596 - ODNodeCustomCall request, NodeID: C4798750-2B7F-471A-9493-A9D0BD7C22D2, Code: 82
2016-03-03 06:44:10.308156 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Bind Step 1 - Searching for Forest/Domain information - 'corp.PRETENDCO.com'
2016-03-03 06:44:10.308288 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Removing Kerberos reachability info 'Kerberos:CORP.PRETENDCO.COM'
2016-03-03 06:44:10.308391 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - client requested OU - 'OU=Office,OU=Macintosh,OU=Region,DC=corp,DC=PRETENDCO,DC=com'
2016-03-03 06:44:10.308408 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Binding using 'bradtchapman@CORP.PRETENDCO.COM' for kerberos ID
2016-03-03 06:44:10.308884 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - new kerberos credential cache 'MEMORY:0x7fb77b321940' for 'bradtchapman@CORP.PRETENDCO.COM'
2016-03-03 06:44:10.311875 CST - Trigger - new node trigger watching for 'opendirectoryd:nodes;(register|unregister);.*'
2016-03-03 06:44:10.311985 CST - 14661.243597 - Client: distnoted, UID: 501, EUID: 501, GID: 20, EGID: 20
2016-03-03 06:44:10.312016 CST - 14661.243597 - RPC: getpwuid, Module: SystemCache, uid: 501, rpc_version: 2
2016-03-03 06:44:10.312091 CST - 14661.243597, Module: SystemCache - getpwuid completed, delivered 1 result
2016-03-03 06:44:10.315430 CST - 17.243598 - Client: syslogd, UID: 0, EUID: 0, GID: 0, EGID: 0
2016-03-03 06:44:10.315464 CST - 17.243598 - RPC: mbr_identifier_translate, Module: SystemCache, Value: 501, Requesting: UUID, Type: UID
2016-03-03 06:44:10.315516 CST - 17.243598, Module: SystemCache - UUID = '82A88CD6-B60C-4A01-8AA6-D0DC5EC5304A' from user macadmin@/Local/Default (0x7fb781200170)
2016-03-03 06:44:10.315549 CST - 17.243598, Module: SystemCache - mbr_identifier_translate completed, delivered 1 result
2016-03-03 06:44:12.617632 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - valid credentials for bradtchapman@CORP.PRETENDCO.COM
2016-03-03 06:44:12.617644 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:12.617650 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:12.688309 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apklnmdc002pv.corp.PRETENDCO.com'
2016-03-03 06:44:12.688338 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:12.688342 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:12.688694 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:12.698413 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:13.047621 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'euathmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:13.047651 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:13.047656 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:13.047853 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:13.262589 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:13.603773 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nalewmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:13.603802 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:13.603807 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:13.604023 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:13.852455 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:13.867498 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apcacmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:13.867527 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:13.867531 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:13.867671 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:13.875938 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:14.244160 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'namidmdc002pv.corp.PRETENDCO.com'
2016-03-03 06:44:14.244189 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:14.244194 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:14.244353 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:14.443553 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:14.443660 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eumaimdc002pv.corp.PRETENDCO.com'
2016-03-03 06:44:14.443686 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:14.443690 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:14.443860 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:14.634420 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:14.634529 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eulismdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:14.634556 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:14.634560 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:14.634684 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:14.850675 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:14.850784 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eurunm01a.corp.PRETENDCO.com'
2016-03-03 06:44:14.850811 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:14.850815 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:14.850945 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:15.038932 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:15.079598 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'aphenmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:15.079626 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:15.079631 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:15.079775 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:15.080546 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:15.445970 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'naaurmdc002pv.corp.PRETENDCO.com'
2016-03-03 06:44:15.446001 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:15.446005 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:15.446174 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:15.653514 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:15.653624 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'namidmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:15.653654 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:15.653658 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:15.653802 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:15.853687 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:15.853791 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'lamexmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:15.853824 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:15.853828 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:15.853996 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:16.057367 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:16.057472 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'naaurm01b.corp.PRETENDCO.com'
2016-03-03 06:44:16.057506 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:16.057511 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:16.057638 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:16.265503 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:16.265610 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nandcmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:16.265636 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:16.265641 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:16.265824 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:16.461811 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:16.461923 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'napdcmdmct006pv.corp.PRETENDCO.com'
2016-03-03 06:44:16.461949 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:16.461954 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:16.462098 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:16.621052 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:16.974372 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apckrmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:16.974401 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:16.974405 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:16.974581 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:17.033410 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:17.397390 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nanycm01a.corp.PRETENDCO.com'
2016-03-03 06:44:17.397419 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:17.397424 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:17.397600 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:17.616258 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:17.616372 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eulanmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:17.616402 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:17.616406 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:17.616535 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:17.814959 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:17.815082 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'lamabmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:17.815109 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:17.815113 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:17.815282 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:18.054176 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:18.054286 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eulism01a.corp.PRETENDCO.com'
2016-03-03 06:44:18.054314 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:18.054319 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:18.054443 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:18.270320 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:18.285470 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'aphmnmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:18.285500 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:18.285504 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:18.285653 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:18.294549 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:18.645326 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nasbdmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:18.645371 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:18.645376 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:18.645576 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:18.801870 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:19.144343 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nawbym01a.corp.PRETENDCO.com'
2016-03-03 06:44:19.144376 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:19.144381 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:19.144579 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:19.366302 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:19.366424 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nalarm01a.corp.PRETENDCO.com'
2016-03-03 06:44:19.366453 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:19.366457 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:19.366620 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:19.557604 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:19.691672 CST - 39.243599, Module: SystemCache - Client: mds
2016-03-03 06:44:19.691728 CST - 39.243599, Module: SystemCache - RPC: kauth_membership_check, Module: SystemCache, Provided: [ User (UID: 89), Group (GID: 80) ], SeqNo: 51903, Requesting: [ Membership Confirmation ]
2016-03-03 06:44:19.691810 CST - 39.243599, Module: SystemCache - is user _spotlight@/Local/Default (0x7fb781600170) a member of group with UUID ABCDEFAB-CDEF-ABCD-EFAB-CDEF00000050 == false - TTL 120
2016-03-03 06:44:19.691868 CST - 39.243599, Module: SystemCache - kauth_membership_check completed, delivered 1 result
2016-03-03 06:44:19.929527 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'euamsmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:19.929560 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:19.929565 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:19.929745 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:20.115345 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:20.115455 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'lasaom01a.corp.PRETENDCO.com'
2016-03-03 06:44:20.115490 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:20.115495 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:20.115634 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:20.438773 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:20.438887 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'euldcmdmct002pv.corp.PRETENDCO.com'
2016-03-03 06:44:20.438913 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:20.438918 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:20.439059 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:20.627661 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:20.995018 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eubarmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:20.995048 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:20.995053 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:20.995225 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:21.194456 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:21.194564 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eumilmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:21.194604 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:21.194609 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:21.194727 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:21.382553 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:21.382662 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apckrm01b.corp.PRETENDCO.com'
2016-03-03 06:44:21.382700 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:21.382705 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:21.382839 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:21.439945 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:22.142565 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apmszmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:22.142595 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:22.142599 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:22.142784 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:22.303846 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:22.303915 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - socket 33 failed
2016-03-03 06:44:22.303962 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'nandcmdc001p.corp.PRETENDCO.com'
2016-03-03 06:44:22.303989 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:22.303994 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:22.304120 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:22.501262 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:22.501364 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'lasanm01a.corp.PRETENDCO.com'
2016-03-03 06:44:22.501390 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:22.501395 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:22.501525 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:22.790373 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:22.790481 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'namism01a.corp.PRETENDCO.com'
2016-03-03 06:44:22.790512 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:22.790517 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:22.790651 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:22.994408 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:23.368617 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apshamdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:23.368649 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:23.368653 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:23.368815 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:23.401810 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:23.401917 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'eumaimdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:23.401944 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:23.401948 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:23.402076 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:23.591408 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:23.591536 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'namonmdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:23.591563 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:23.591567 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:23.591696 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:23.802865 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:23.802977 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'apkuamdc001pv.corp.PRETENDCO.com'
2016-03-03 06:44:23.803005 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:23.803010 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:23.803135 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:23.845325 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:24.373670 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - Setting kerberos server for 'Kerberos:CORP.PRETENDCO.COM' to 'naftwm01a.corp.PRETENDCO.com'
2016-03-03 06:44:24.373702 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching to cache 'MEMORY:0x7fb77b321940'
2016-03-03 06:44:24.373706 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - switching GSS to cache 'MEMORY:0x7fb77b321940
2016-03-03 06:44:24.373866 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - setting realm 'CORP.PRETENDCO.COM' for node '/Active Directory/corp.PRETENDCO.com'
2016-03-03 06:44:24.558994 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - failed LDAP operation for 'authenticate connection' with error 'Unknown authentication method'
2016-03-03 06:44:34.386792 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - an error of 2000 occurred - Unable to connect to server
2016-03-03 06:44:34.387065 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - ODNodeCustomCall failed with error 'Unknown node name' (2000)
2016-03-03 06:44:34.387098 CST - 14659.243596, Node: /Active Directory, Module: ActiveDirectory - excessive time for request - 24.078 seconds
2016-03-03 06:44:34.390495 CST - 14659 - Client: 'dsconfigad', exited with 0 session(s), 2 node(s) and 0 active request(s)
2016-03-03 06:44:34.390566 CST - 14659.243600 - ODNodeRelease request, NodeID: 50446591-5A85-4BBE-94E4-ADBE61189DFB
2016-03-03 06:44:34.390592 CST - 14659.243601 - ODNodeRelease request, NodeID: C4798750-2B7F-471A-9493-A9D0BD7C22D2
2016-03-03 06:44:34.390675 CST - 14659.243600, Node: /Configure - ODNodeRelease completed
2016-03-03 06:44:34.390680 CST - 14659.243600, Node: /Configure - closed nodeID 50446591-5A85-4BBE-94E4-ADBE61189DFB
2016-03-03 06:44:34.390692 CST - 14659.243601, Node: /Active Directory - ODNodeRelease completed
2016-03-03 06:44:34.390695 CST - 14659.243601, Node: /Active Directory - closed nodeID C4798750-2B7F-471A-9493-A9D0BD7C22D2
2016-03-03 06:44:34.390764 CST - clearing all node authentication connections
2016-03-03 06:44:34.390827 CST - clearing all node authentication connections
2016-03-03 06:44:34.390837 CST - Trigger - cancelled
2016-03-03 06:44:34.393971 CST - 14656 - Client: 'sudo', exited with 0 session(s), 2 node(s) and 0 active request(s)
2016-03-03 06:44:34.394031 CST - 14656.243602 - ODNodeRelease request, NodeID: 7EEB3646-3F99-44BF-B956-C2339C451FEC
2016-03-03 06:44:34.394071 CST - 14656.243603 - ODNodeRelease request, NodeID: E53FA6A0-C86C-4C11-B82B-A834987B6DA2
2016-03-03 06:44:34.394074 CST - 14656.243602, Node: /Local/Default - ODNodeRelease completed
2016-03-03 06:44:34.394079 CST - 14656.243602, Node: /Local/Default - closed internal nodeID 7EEB3646-3F99-44BF-B956-C2339C451FEC
2016-03-03 06:44:34.394111 CST - 14656.243603, Node: /Search - ODNodeRelease completed
2016-03-03 06:44:34.394117 CST - 14656.243603, Node: /Search - closed internal nodeID E53FA6A0-C86C-4C11-B82B-A834987B6DA2
2016-03-03 06:44:34.394147 CST - clearing all node authentication connections
2016-03-03 06:44:34.394207 CST - clearing all node authentication connections
2016-03-03 06:44:34.394216 CST - Trigger - cancelled
  • March 8, 2016
What is your bind method/ workflow that you are doing?
bradtchapman
  • March 8, 2016
Our standard workflow involves the use of a JSS active directory bind action. Most of the computers company-wide have no problems, but many computers in certain offices in China are having a high degree of AD bind failures.
What you are seeing here is a debug log. I need help with some advanced AD and DNS record troubleshooting.
  • March 8, 2016
@bradtchapman I'm just throwing this out there, I didn't really even look at the logs, but recently I've had a slew of computers running OS X 10.8.5 that are losing their bind for no reason and I cannot re-bind without getting an error message, one of which is "Unable to store password"
The only fix I've had is to re-image the machine or update to a new OS X and I have yet to see it on any other OS X than 10.8.5. Just a thought that it may be something with 10.8.5.
