App Install stuck in Pending Status
  • October 11, 2019
  • 0 replies
  • 13 views
I added tvOS Browser as an in house app in JAMF. I used xcode to edit what I needed to. I can install it on an enrolled Apple TV when it's directly connected to the computer with Xcode with no problem. I was also able to add the .ipa file to JAMF and push it out to another Apple TV that I used for testing. However, I tried pushing it out to the Apple TV that it needs to be installed on and the status is pending under management commands. The icon for the app appears on the Apple TV, but it says Waiting. When you click on it, "Unable to Install "tvOS Browser." Please try again later. Why would this work on one enrolled device but not another? Does anyone know what I should check?
