Fix Byhost not working?
  • May 17, 2012
  • 0 replies
  • 11 views
awjohnso
Greetings,
I'm evaluating Casper Suite so I'm still very new to it. I've setup an OS deployment, SW packages, and user configs in my testing environment. I'm trying to Fix ByHost Files and it's not working. I tried from Casper Remote, and from the actual workstation in question from the command line.
The error I get is:
jamf(13086) malloc: *** mmap(size=1073745920) failed (error code=12)
*** error: can't allocate region
*** set a breakpoint in malloc_error_break to debug
terminate called throwing an exceptionAbort trap: 6
The OS is 10.7.4 on a mid 2007 iMac. The ByHost on this machine should be the MAC Address and not the UUID.
Any suggestions?
Thanks,
Andrew
Andrew W. Johnson
Senior Macintosh Systems Administrator
Department of Teaching Learning + Technology
Division of Information Technology
Stony Brook University
S-1464 Frank Melville Jr. Memorial Library
Stony Brook, NY 11794-3350
Tel: (631) 632-1824
Fax: (631) 632-1373
