Jamf Connect Menubar — Google's Change & Reset Password Pages Blank
  • December 7, 2022
  • 80 views
Hi There,
I am a noob so please excuse my ignorance. We have a new install connected to GoogleID and have had an issue from the beginning where the Jamf Connect Menubar's Change Password and Reset Password pages comes up blank. I've tried changing default browsers with no luck. I've made sure both browsers were signed into the Google account with no luck. The Connect option seems to work and pulls up the correct email and password info as it logs in. I should add that other than that Jamf Connect seems to be working as expected.
Here's what the plist info is set to.
I appreciate any help you all can offer as I'm stumped.
-Jason
<plist version="1.0">
<dict>
<key>ChangePasswordURL</key>
<string>https://myaccount.google.com/intro/signinoptions/password</string>
<key>PasswordChangeWorkflow</key>
<string>Web</string>
<key>Appearance</key>
<dict>
<key>ShowWelcomeWindow</key>
<false/>
</dict>
<key>CustomMenuItems</key>
<dict>
<key>getsoftware</key>
<string>Agency Self Service</string>
</dict>
<key>HiddenMenuItems</key>
<array>
<string>preferences</string>
</array>
<key>IdPSettings</key>
<dict>
<key>Provider</key>
<string>GoogleID</string>
</dict>
<key>PasswordPolicies</key>
<dict>
<key>CheckOnNetworkChange</key>
<true/>
<key>NetworkCheck</key>
<integer>60</integer>
</dict>
<key>SignIn</key>
<dict>
<key>AutoAuthenticate</key>
<true/>
<key>PasswordLabel</key>
<string>Password</string>
<key>RequireSignIn</key>
<true/>
<key>UsernameLabel</key>
<string>Email Address</string>
<key>WindowTitle</key>
<string>Please login with your Google email and password</string>
</dict>
<key>UserHelp</key>
<dict>
<key>SoftwarePath</key>
<string>/Applications/Agency Self Service.app</string>
</dict>
</dict>
</plist>
Callum_Williams
Hi all, im having similar issues. I’m also noticing that the Connect button does not work, its reporting an “unexpected error”
_Daley
  • October 21, 2025
