Hi All,
Anyone have any luck automating the Security & Privacy allow settings for SMARTBoardService.app in Mojave.
Tried using the PPPC utility from github. What happens is I can create a profile for SMARTNotebook.app but not for the SMARTBoardService.app and I am guessing I will have the same problem with SMARTInk.app.
If I run codesign I can see that SMARTNotebook is signed but the other 2 apps are not. No signing probably explains why those Apps don't work in PPPC.
Can anyone point me to a next step. SMART tech support has sent me links that show how the user can allow the app.
I think the manufacturer has to apply for the signing - so that is a dead end (unless I am mistaken). I also saw some threads that apps get signed but not necessarily "utilities" so I am wondering if that is true also.
I have KEXT profiles already from using this version of SMART on HighSierra - I am assuming these are OK on Mojave too (unless I am mistaken).
I was hoping the answer was not that this was a manual user process - thank you in advance.
