iCloud Disable and Remove
  • April 17, 2017
  • 0 replies
  • 2 views
Currently we have random employees that have iCloud enabled, i can disable most of iCloud and turn all the features off (except find my mac). I'm fine with keeping Find my Mac enabled and the account enabled on the machine but when iCloud has a notification it wont let you get rid of the notification without opening the iCloud system preference (which is blocked). Is there a way to disable notifications for iCloud? or remove iCloud All together? i cant seem to find a good answer on completely signing out of iCloud. I just need an easy way to disable and sign out remotely, disable and turn off notifications, or a way to prompt the user to signout themselves. I did notice that there is no way to sign out of iCloud if the system preference is grey out for the user. (Including if internet accounts are not disabled).
I used this script to disable everything: [https://www.jamf.com/jamf-nation/discussions/23312/completely-disable-icloud](link URL)
