System Preferences - Keyboard - Shortcuts - ScreenShots
I'll be playing with this shortly, seems pretty straight forward.
            Hey @larry_barrett,
I feel like I've been banging my head against a wall for the last month! Did you find a way to remove that configuration by policy? We have over 1000 Macs that would need to be changed, and I assume it's per user profile.
            @Ricky See this thread. My response (galionschools) is about halfway down the page. Trial it out first by deleting com.apple.symbolichotkeys from the user library ( ~/Library/Preferences ) and launching the browser. Not sure if it still applies as they may have changed things since then but it's worth a shot.
            @Ricky I don't know if you are still looking for an answer but I just got this figured out. We have two configuration profiles: one for all the keyboard shortcuts and the other for the Searching shortcuts.
You modify the keyboard shortcuts according to your finding and @mainelysteve post. Then disable the Searching shortcuts (System Preferences >> Keyboard >> Shortcuts >> Services >> Searching). These changes are made in the com.apple.symbolichotkeys.plist and pbs.plist in ~/Library/Preferences/
You then create a configuration profile and upload these plists in as Custom Settings. You can set the Level to User Level and Limitations to the specific test user.
Hope this help.
            @hphan If you generate out a plist, how do you get the configuration to apply out to machines? Just set the preference domain to com.apple.symbolichotkeys ?
            After fiddling with Mojave for hours of our precious lives, our team has concluded that overwriting custom settings via configuration policy doesn't work for system preferences. We tested this with applying profiles at a user and a computer level on our Mojave instances with no luck.
We did, however, find a method that actually works to get CA Secure Browser (SBAC) compliant in our environment!
Our first step was to generate up our plist files that would be used as our template. The settings were configured in System Preferences > Keyboard > Shortcuts with the following Unchecked:
- Mission Control
- Mission Control (dropdown menu)
- Everything under the Screenshots sidebar
- Spotlight > Show Spotlight search
With that done, it's now time to collect our plists. I navigated to ~/Library/Preferences/ and copied both com.apple.symbolichotkeys.plist and com.apple.spaces.plist to /Users/Shared/
Using composer we built out a pkg that installs on the target machine as /Users/Shared/
Now we need to move those plists into the appropriate location. Thankfully we can use JAMF's handy dandy Scripts module:
sleep 5
mv /Users/Shared/com.apple.symbolichotkeys.plist /Users/$3/Library/Preferences/com.apple.symbolichotkeys.plist
mv /Users/Shared/com.apple.spaces.plist /Users/$3/Library/Preferences/com.apple.spaces.plist
We included the 5 second for good measure. The likelihood of a student logging into a machine and then immediately clicking the CA Secure Browser application is very low. We'd rather give the computer a second to generate up all the Preference files. Then we simply move the files from that /Users/Shared/ folder into the logged in user (JAMF has this pre-defined as $3).
Build out a policy with the following configuration:
Login Trigger
Once per user per computer
Attach the .pkg file that we just generated up in Composer that installs to /Users/Shared/
Run the script with the "After" priority defined
For good measure, we have it check in with JAMF so we can log what happened.
Finally, under User Interaction Complete Message saying the computer is ready for testing. This is nice so we can relay to our end users that they need to wait for the popup message the first time they log in.
That's it! You're done. This resolves both the Spaces / Mission Control issue as well as the shortcuts issue seen when a student logs in for testing.
            I did this without the need for a script by creating a policy to install the package on login with the "Fill existing user home directories option" selected.
