I'm deploying a new machine for the first time using connect 2.9. Right after DEP installs our configuration profiles and the connect pkg, We get the menu bar app login pop-up. This is before the 365 login presents itself. The popup is not branded and if anything is provided, it fails. However, if you close the popup, the deployment proceeds fine. What setting is controlling this behavior?
Heya, this is addressed in Connect 2.9.1, which was released this week.
https://community.jamf.com/t5/jamf-connect/jamf-connect-2-9-1-now-available/td-p/259538
  • ​​[PI109800] Jamf Connect no longer launches prematurely while users are setting up their Mac with Apple Setup Assistant.​
