401 Error while using API to add members to group
We have a .Net C# application that runs on a Windows 2012 server and is attempting to add members to a static group via a PUT command and is throwing a 401 Unautorized error for each operation. The error is as follows:
2016-08-01 18:17:12,302 [ERROR] (PROGRAM.Helpers.JssHttpHelper) WebException at 'https://testdomain.com:8443/JSSResource/computergroups/id/18'. Exception:
System.Net.WebException: The remote server returned an error: (401) Unauthorized.
The code is question is:
using System;
using System.Text;
using System.Net;
using System.Net.Security;
using System.IO;
using log4net;
using System.Reflection;
namespace Program.Helpers
    public static class JssHttpHelper
        private static readonly ILog _log = LogManager.GetLogger(MethodBase.GetCurrentMethod().DeclaringType);
        public static void PutXml(string jssUrl, string username, string password, string url, string xml)
            var credentialCache = new CredentialCache();
            credentialCache.Add(new Uri(jssUrl), "Basic", new NetworkCredential(username, password));
            HttpWebResponse response = null;
            try
                var request = (HttpWebRequest)WebRequest.Create(url);
                request.Method = "PUT";
                request.ContentType = "text/xml";
                request.Credentials = credentialCache;
                request.KeepAlive = true;
                request.ContentLength = xml.Length;
                ServicePointManager.ServerCertificateValidationCallback =
                    new RemoteCertificateValidationCallback((a, b, c, d) => { return true; });
                using (Stream stream = request.GetRequestStream())
                    UTF8Encoding encoding = new UTF8Encoding();
                    byte[] bytes = encoding.GetBytes(xml);
                    stream.Write(bytes, 0, bytes.Length);
                    stream.Close();
                using (response = (HttpWebResponse)request.GetResponse())
                    if (response.StatusCode == HttpStatusCode.Created || response.StatusCode == HttpStatusCode.OK)
                        _log.Info(string.Format("Successfully sent a put request to '{0}'.", url));
                        return;
                        throw new Exception(string.Format("Response Failure: HttpStatus {0} - {1}", response.StatusCode, response.StatusDescription));
            catch (WebException ex)
                _log.Error(string.Format("WebException at '{0}'. Exception: {1}", url, ex.ToString()));
                if (ex.Status == WebExceptionStatus.ProtocolError)
                    response = ex.Response as HttpWebResponse;
                    if (response != null)
                        _log.Info(string.Format("WebExceptionStatus.ProtocolError at '{0}'. HttpWebResponse: '{1}' ", url, response.ToString()));
                throw;
            catch (Exception ex)
                _log.Error(string.Format("Exception at '{0}'. Exception: {1}", url, ex.ToString()));
                throw;
            finally
                    response.Close();
Has anyone experienced the 401 error while attempting to add members to a group or a similar operation? Thank you for your consideration.
Best answer by dwandro92
Does the authenticating user have "Update" permissions for Static User Groups?
  • 125 replies
  • August 2, 2016
donmontalvo
Forum|alt.badge.img+36
  • 4293 replies
  • August 2, 2016
@dwandro92 Richard might owe you some GREEN (hit "helpful"), that did the trick! :)
  • August 2, 2016
Thanks dwandro92 - that was the issue. Much appreciated!
Cookie policy
Cookie settings
