A script for deployment of multi-instance JSS (Linux)
kitzy
  • 167 replies
UPDATE: I've moved the script to GitHub: https://github.com/jkitzmiller/jssdeploy
Version 9 here: https://github.com/jssmanager/jssmanager/
  • 89 replies
  • November 17, 2012
Well done. Very well done.
kitzy
  • 167 replies
  • November 17, 2012
Thank you!
  • 89 replies
  • November 17, 2012
Next lab machine I have, I will play with this.
kitzy
  • 167 replies
  • November 17, 2012
I used it successfully in production for the first time tonight. It went off without a hitch. Of course it IS tailored to my environment...
kitzy
  • 167 replies
  • November 18, 2012
I just made some changes to make it a little more user friendly, specifically adding variables at the beginning to let you define where you keep your logs and your ROOT.war file. The formatting is also a little nicer when asking for user input.
kitzy
  • 167 replies
  • November 20, 2012
Made a couple of tweaks, mostly improving documentation and adding support for Tomcat being installed as a service.
kitzy
  • 167 replies
  • December 3, 2012
Updated to incude error checking and slightly improved documentation.
Has anyone played with it yet? I'd love to hear your thoughts.
tobiaslinder
  • 101 replies
  • January 25, 2013
I just wanted to report back that the script worked perfectly fine after tweaking a few settings but this is probably due to the fact that I used the jssinstaller.run and not the manual installation.
Thank you so much for this brilliant script. I will have to setup many instances in the near future and so this is going to make my life way easier. Looking forward to invite you for a drink of your choice next time I'm in Chicago (probably summer 2014).
  • 1892 replies
  • January 25, 2013
Git hub this. Now.
kitzy
  • 167 replies
  • January 28, 2013
Tobias - I'm glad you found it helpful! I'll definitely take you up on that drink!
Jared- I've been meaning to... time is not on my side. One of these days!
kitzy
  • 167 replies
  • January 28, 2013
EDIT: All is well.
tobiaslinder
  • 101 replies
  • January 28, 2013
What a shame but I understand. My last employer would also not have been happy for me sharing knowledge. 20th century thinking is still very strong is today's management culture.
  • 1892 replies
  • January 28, 2013
Employers are stupid. I grabbed the Google cached version for later keeping.
Forum|alt.badge.img+31
  • 920 replies
  • January 28, 2013
John,
Let me know if there'd be a problem with my hosting the script on my GitHub repo.
Thanks,
Rich
  • 7882 replies
  • January 28, 2013
Wow, really? That's pretty dumb. The next time management asks you to research something out there that you don't already have the answer to I would respond by saying. 'well, found some information, but I can't use it due to the employers owner not allowing them to share it' Employers need to wake up and understand that information sharing is what makes so much of what we do possible in the first place.
kitzy
  • 167 replies
  • January 31, 2013
So I've moved the script to GitHub, and I've added some more error checking. I'm pretty sure it's solid, but I'd love to get some feedback if anyone would like to try it out.
Next on the roadmap is the ability to set an instance as limited access from the script rather than having to log in to the JSS instance.
kitzy
  • 167 replies
  • February 3, 2013
Added some error checking for the database connection.
Still working on limited access, and possibly the option to create the database and user from the script.
talkingmoose
Forum|alt.badge.img+36
  • Community Manager
  • 1906 replies
  • February 3, 2013
echo Configuration complete. Enjoy your burrito.
Heh heh heh...
kitzy
  • 167 replies
  • February 3, 2013
I was wondering how long it would take someone to comment on that.
kitzy
  • 167 replies
  • February 6, 2013
I tested it with version 8.63, and it worked great in my environment! I also fixed a couple bugs. Check github for the details.
kitzy
  • 167 replies
  • February 10, 2013
I'm looking for a couple people to test out setting limited access from the script. Would anyone like to help?
kitzy
  • 167 replies
  • August 21, 2013
This script has been updated for version 9 and has a ton of new features.
Please use at your own risk, as this is provided "as is" and is not JAMF supported. Please test before using in your production environment.
-Kitzy
rickgmac
  • 62 replies
  • September 26, 2013
Any tips on changing ports.
Seams to create instances with port 8080. If I change the server.xml tomcat won't start.
kitzy
  • 167 replies
@rickgmac - The ports are all handled by Tomcat, so it's not that the script is creating the contexts on port 8080, that's just Tomcat's default configuration.
In my server.xml, I have a section for 8443 that looks something like this:
<Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true" maxThreads="150" scheme="https" secure="true" clientAuth="false" sslProtocol="TLS" keystoreFile="/var/lib/tomcat7/cert.p12" keystorePass="password" keystoreType="PKCS12" />
I believe this section is commented out by default on a standard Tomcat install.
If you post your server.xml here, I'm sure someone could help you figure out why Tomcat won't start.
-Kitzy
rickgmac
  • 62 replies
Cheers kitzy
Made a rookie mistake, by not fully un-commenting the connector. So Tomcat would fail to start.
Love this script by the way.
Cookie policy
Cookie settings
