You'd definitely would have to script that and use the API. I'm working on something similar will share it with you in a few weeks when it's ready.
Also, please up vote this feature request which I think would fulfill what you're looking to do:
https://jamfnation.jamfsoftware.com/featureRequest.html?id=3511
Been awhile since I've done it, but if the jamf binary still has the -endUsername flag you can do something like this:
lastUser=`defaults read /Library/Preferences/com.apple.loginwindow lastUserName`
jamf recon -endUsername $lastUser
That will grab the short name of the user logged in and then the jamf binary will do a recon and flow that up to the computer record in the JSS.
BOOM Jared! Perfect. Execute it only once and it permanently assigns the device on first login.
Thank you!
Interesting. defaults read /Library/Preferences/com.apple.loginwindow lastUserName returns a value of _mbsetupuser for me when run by a AD user from a Mac bound to AD.
Like I said, been awhile since I've done it. There's a zillion ways to determine logged in user so use the method that's preferred for you and returns a reliable result. A lot of folks grab the owner of /dev/console (myself included) and use that.
The big missing piece was getting it to flow up to the JSS and that's where -endUsername comes in.
We've been using this (from 9.32 to 9.65 currently) and it works great.
Set to run at login, once per week. I got this from another thread on this and we have mostly AD users, FWIW.
Also need to make sure that "Collect user and location information from LDAP" is on under:
Computer Management/Computer Inventory Collection/General.
/usr/sbin/jamf recon -endUsername $3
The only problem I can see with that running at login is if you login as the admin account or some other account that doesn't really belong to the person. Obviously every environment is different, but if either of those are possibilities then that's something to consider.
@bpavlov - yes, that happens on occasion. But for the majority of the time, we get the user. Only time someone is logged in locally is when a tech is working on the Mac, so as an example, my last report of 858 Macs, there were a handful of those.
It's better than what we had which was nothing. If there's a better option, I'm open to it.
@scottb @bpavlov Why not limit it to a specific LDAP group, or exclude a group that contains your admins as well as a local user, ex: exclude Techs, localadmin and caspermanage
@usher.br Using that script by @scottb you could certainly hardcode and leave out certain usernames in the script using an if statement to exit if the blacklisted user logs in. But you still may have situations where maybe another user logs into someone else's account (shouldn't be too common but it can happen). Doesn't necessarily have to be a tech. Either way, it's just something to be aware of.
Right now it's pulling "root" as the user unless I sign in right after the initial profile pushes down.
We run the following script at login with a policy. The script creates a breadcrumb (file) on the machine which contains the username. We then have an extension attribute that picks up the username out of the breadcrumb file and we exclude the policy from running on computers that already have this breadcrumb, and also exclude admin users etc. What ends up happening is the second time the script is run the username is set in the JSS. This works perfectly for our needs.
logfile=/var/log/jamf.log;
exec >> $logfile 2>&1;
scriptname="populate_username.sh";
breadcrumb="/Library/BCGS/breadcrumb_username_populated.txt";
currentUser=`defaults read /Library/Preferences/com.apple.loginwindow lastUserName` >/dev/null 2>/dev/null
if [ `ls -l /dev/console | cut -d " " -f 4` == "root" ]
then
LoggedInUser=$3
LoggedInUser=`ls -l /dev/console | cut -d " " -f 4`
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: "
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: ------------------------------------------------------"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: --- Starting $scriptname"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Script variables:"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: $LoggedInUser = $LoggedInUser"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: $currentUser = $currentUser"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]:"
if [ -f "$breadcrumb" ]
then
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Skipped populating the username as we have already done this."
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Username is '$currentUser'."
if [ $LoggedInUser == $currentUser ]
then
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Usernames are the same ($LoggedInUser, $currentUser)"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Running 'jamf recon -endUsername $LoggedInUser."
jamf recon -endUsername $currentUser >/dev/null 2>/dev/null
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Creating the breadcrumb."
echo $LoggedInUser >> $breadcrumb
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Running jamf recon for a second time."
jamf recon >/dev/null 2>/dev/null
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: Usernames are not the same ($LoggedInUser, $currentUser)"
echo "`date +"%a %b %d %X"` `hostname` jamf[script-$scriptname]: --- Finished $scriptname -----------------------------"
I'm trying to accomplish nearly the same thing as the original poster. The difference is that I'd like to have my users do it in one-time computer distribution sessions via Self Service - and thereafter the policy will be unavailable.
However, I can't seem to get the $3 variable to work. If I enter 'jamf recon -endUsername testuser' via a policy and script or type it into the terminal with sudo, then it works fine. Once I try to use 'jamf recon -endUsername $3' the policy runs without error but nothing is changed in the inventory.
Anyone have any suggestions as to what I'm doing wrong? I'm using JSS 9.73 and testing on 10.10.3 and 10.10.4 clients. Our macs are AD-bound and I'm testing with AD users, both local admins and standard accounts. I copied the script straight out of scottb's comment:
Do you have it being run on login? Not sure if that would fix it.
See https://jamfnation.jamfsoftware.com/article.html?id=146 on how $3 is added. You may be able to test it with self service too just to make sure it works without having to login and out all the time. Just make sure to login to self service as the account you want to test with
Thanks for the link, @brandonusher. It seems that the $3 variable requires the policy to be run at login or logout. I'll have to come up with another way to do it. Thanks.
You could try something like this:
loggedInUser=`python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
/usr/sbin/jamf recon -endUsername $loggedInUser
Don't forget, if the script isn't being run by the JSS you'll have to sudo the jamf command
@brandonusher, that works perfectly! Thanks for your help.
Question,
Is there a way to make the JSS lookup the ldap info for that user? I love that this puts the username in the correct field in the inventory however unless I click the magnify glass icon in the JSS UI it won't lookup the ldap info. Would love to have this scripted as well.
Gabe Shackney
Princeton Public Schools
