Automatically add AD users to FileVault 2 enabled users
Does anyone have a good solution or workflow for adding additional active directory users to be enabled for FileVault 2 access to a local machine? Create a local user and it automatically gets added, but not an Active Directory user.
  • Employee
  • 36 replies
  • September 9, 2014
+1 on this. I have a requirement from one of my colleges....
  • 7883 replies
  • September 9, 2014
Not sure if there's a way to fully automate adding them in without some interaction, but if you have things set up just so, you may be able to do it in a scripted method that gets the account password as part of the process. Take a look at what @stevewood is doing in his environment on this thread. This is related to a domain move, but part of that is adding the AD account to the FV2 authorized list
https://jamfnation.jamfsoftware.com/discussion.html?id=11606
stevewood
Forum|alt.badge.img+35
  • 1798 replies
  • September 9, 2014
I did a test rollout of that process with 4 users, and the only ones that had troubles were those that had a home folder named different than their AD user name. So I have to go back and add in some testing/fixing for that. But otherwise, it worked great.
Cookie policy
Cookie settings
