Cisco Secure Client Uninstall Script (5.1.2.42)
  • March 28, 2024
  • 17 replies
  • 2560 views
Hello Jamf Community,
iam looking for a Script to uninstall the Cisco Client Silent.
I have a script that does it, but the Users will always get a Pop-Up Message that the Socket Filter needs Admin Permission. You can ignore the window, and it is uninstalled, but I would like to have it more clean.
Greetings TGD
mvu
Forum|alt.badge.img+22
  • March 28, 2024
Are you running this script?
/opt/cisco/secureclient/bin/cisco_secure_client_uninstall.sh
  • April 1, 2024
If you use the XML custom setup, this pop-up doesn't appear. Would highly recommend but takes some time to setup. https://docs.umbrella.com/umbrella-user-guide/docs/customize-macos-installation-of-cisco-secure-client
Otherwise, I had to make a script to make the user an admin, install the software, remove the components (thousand eyes, DART, etc...), and then demote the user admin rights. This way the user can at least use their credentials to accept or cancel out. We found an issue with the umbrella going this route, that the umbrella wasn't active until after the first time the user connected to the VPN.
CSCC-JS
  • April 1, 2024
I used Suspicious Package https://mothersruin.com/software/SuspiciousPackage/ to copy out uninstall script(s) from the pkg installer(s). To make back up "clean up" removal policies when the normal process (invoke the uninstall script) fails.
Here's the VPN/VPN Socket removal script from the pkg (but won't remove the other module(s) from 5.1.2.42
#!/bin/bash INSTPREFIX="/opt/cisco/secureclient" BINDIR="${INSTPREFIX}/bin" PLUGINDIR="${BINDIR}/plugins" LIBDIR="${INSTPREFIX}/lib" PROFDIR="${INSTPREFIX}/vpn/profile" MGMTPROFDIR="${INSTPREFIX}/vpn/profile/mgmttun" SCRIPTDIR="${INSTPREFIX}/vpn/script" HELPDIR="${INSTPREFIX}/help" KEXTDIR="/Library/Application Support/Cisco/Cisco Secure Client" APPDIR="/Applications/Cisco" GUIAPP="Cisco Secure Client.app" NWEXT_KDF_APP="Cisco Secure Client - Socket Filter.app" UNINSTALLER="Uninstall Cisco Secure Client.app" LAUNCHD_DAEMON_DIR="/Library/LaunchDaemons" LAUNCHD_DAEMON_VPNAGENT_FILE="com.cisco.secureclient.vpnagentd.plist" LAUNCHD_AGENT_DIR="/Library/LaunchAgents" LAUNCHD_AGENT_GUI_FILE="com.cisco.secureclient.gui.plist" LAUNCHD_AGENT_NOTIFICATION_FILE="com.cisco.secureclient.vpn.notification.plist" ACMANIFESTDAT="${INSTPREFIX}/VPNManifest.dat" VPNMANIFEST="ACManifestVPN.xml" LOGDIR="/var/log/secureclient" UNINSTALLLOG="${LOGDIR}/csc_vpn_uninstall.log" KDFDIR="${INSTPREFIX}/kdf" KDF_BINDIR="${KDFDIR}/bin" KDF_LIBDIR="${KDFDIR}/lib" INSTALL_DIR="${INSTPREFIX}/install" COMPONENT_DIR="${INSTALL_DIR}/component" DEPENDENCY_DIR="${INSTALL_DIR}/dependency" SERVICE_APP="Cisco Secure Client - AnyConnect VPN Service.app" CSC_VPN_PACKAGE_ID=com.cisco.pkg.anyconnect.vpn # When AnyConnect VPN is being uninstalled, the plugins for # modules that depend on VPN must also be removed. This is # done to ensure that AnyConnect VPN and dependent modules # have same version. # VPN_DEPENDENT_FILELIST=("${PLUGINDIR}/libacampctrl.dylib" \\ "${PLUGINDIR}/libacampshim.dylib" \\ "${PLUGINDIR}/libacisectrl.dylib" \\ "${PLUGINDIR}/libaciseshim.dylib" \\ "${PLUGINDIR}/libacnvmctrl.dylib" \\ "${PLUGINDIR}/libacswgplugin.dylib" \\ "${PLUGINDIR}/libacumbrellaapi.dylib" \\ "${PLUGINDIR}/libacumbrellactrl.dylib" \\ "${PLUGINDIR}/libacumbrellaplugin.dylib" \\ "${PLUGINDIR}/csc_sfpuiplugin.dylib") # Array of files to remove FILELIST=("${BINDIR}/vpnagentd" \\ "${BINDIR}/vpn_uninstall.sh" \\ "${BINDIR}/cisco_secure_client_uninstall.sh" \\ "${BINDIR}/vpn" \\ "${BINDIR}/vpnmgmttun" \\ "${BINDIR}/acextwebhelper" \\ "${BINDIR}/acinstallhelper" \\ "${BINDIR}/vpndownloader.app" \\ "${BINDIR}/UpdateComponentManifest.json" \\ "${BINDIR}/manifesttool" \\ "${BINDIR}/manifesttool_vpn" \\ "${BINDIR}/SetUIDTool_vpn" \\ "${BINDIR}/Cisco Secure Client - Web Browser.app" \\ "${INSTPREFIX}/AnyConnectLocalPolicy.xsd" \\ "${INSTPREFIX}/gui_keepalive" \\ "${INSTPREFIX}/OpenSource.html" \\ "${INSTPREFIX}/update.txt" \\ "${INSTPREFIX}/${VPNMANIFEST}" \\ "${LIBDIR}/libacciscossl.dylib" \\ "${LIBDIR}/libacciscocrypto.dylib" \\ "${LIBDIR}/libaccurl.4.dylib" \\ "${LIBDIR}/libboost_atomic.dylib" \\ "${LIBDIR}/libboost_filesystem.dylib" \\ "${LIBDIR}/libboost_system.dylib" \\ "${LIBDIR}/libboost_thread.dylib" \\ "${LIBDIR}/libboost_date_time.dylib" \\ "${LIBDIR}/libboost_chrono.dylib" \\ "${LIBDIR}/libvpncommon.dylib" \\ "${LIBDIR}/libvpncommoncrypt.dylib" \\ "${LIBDIR}/libvpnapi.dylib" \\ "${LIBDIR}/libacruntime.dylib" \\ "${PLUGINDIR}/libvpnipsec.dylib" \\ "${PLUGINDIR}/libacfeedback.dylib" \\ "${PLUGINDIR}/libacwebhelper.dylib" \\ "${PLUGINDIR}/libvpnapishim.dylib" \\ "${PLUGINDIR}/libacdownloader.dylib" \\ "${PROFDIR}/AnyConnectProfile.xsd" \\ "${MGMTPROFDIR}/AnyConnectProfile.xsd" \\ "${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE}" \\ "${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE}" \\ "${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE}" \\ "${APPDIR}/${GUIAPP}" \\ "${APPDIR}/${UNINSTALLER}" \\ "${KEXTDIR}/acsock.kext" \\ "${KDFDIR}/gui_kext.plist" \\ "${BINDIR}/Cisco Secure Client - Notification.app" \\ "${KDF_BINDIR}/acsocktool" \\ "${KDF_LIBDIR}/libacsock_api_common.dylib" \\ "${COMPONENT_DIR}/acsock64.json" \\ "${COMPONENT_DIR}/acsock64-kext.json" \\ "${COMPONENT_DIR}/acsock-arm64.json" \\ "${COMPONENT_DIR}/acsock-arm64-kext.json" \\ "${DEPENDENCY_DIR}/vpn_manifest.json" \\ ${VPN_DEPENDENT_FILELIST[@]}) # Create log directory if not exist if [ ! -d ${LOGDIR} ]; then mkdir -p ${LOGDIR} >/dev/null 2>&1 fi echo "Uninstalling Cisco Secure Client..." echo "Uninstalling Cisco Secure Client..." > "${UNINSTALLLOG}" echo `whoami` "invoked $0 from " `pwd` " at " `date` >> "${UNINSTALLLOG}" # Check for root privileges if [ `whoami` != "root" ]; then echo "Sorry, you need super user privileges to run this script." echo "Sorry, you need super user privileges to run this script." >> "${UNINSTALLLOG}" exit 1 fi IS_UPGRADE=${1-false} # update the VPNManifest.dat echo "${BINDIR}/manifesttool -x ${INSTPREFIX} ${INSTPREFIX}/${VPNMANIFEST}" >> "${UNINSTALLLOG}" ${BINDIR}/manifesttool -x ${INSTPREFIX} ${INSTPREFIX}/${VPNMANIFEST} >> "${UNINSTALLLOG}" OS_VER_MAJOR=$(sw_vers -productVersion | awk -F. '{ print $1; }') OS_VER_MINOR=$(sw_vers -productVersion | awk -F. '{ print $2; }') MYUID=`echo "show State:/Users/ConsoleUser" | scutil | awk '/kCGSSessionUserIDKey/ { print $3 }'` # Stop the GUI app launch agent if it exists if [ -e ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE} ] ; then echo "Stopping GUI launch agent..." >> "${UNINSTALLLOG}" logger "Stopping the GUI launch agent..." echo "launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE}" >> "${UNINSTALLLOG}" launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_GUI_FILE} >> "${UNINSTALLLOG}" 2>&1 fi # Stop the Notification app launch agent if it exists if [ -e ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE} ] ; then echo "Stopping Notification launch agent..." >> "${UNINSTALLLOG}" logger "Stopping the Notification launch agent..." echo "launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE}" >> "${UNINSTALLLOG}" launchctl bootout gui/${MYUID} ${LAUNCHD_AGENT_DIR}/${LAUNCHD_AGENT_NOTIFICATION_FILE} >> "${UNINSTALLLOG}" 2>&1 fi # Stop the VPN agent launch daemon if it exists if [ -e ${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE} ] ; then echo "Stopping agent..." >> "${UNINSTALLLOG}" logger "Stopping the VPN agent..." echo "launchctl bootout system ${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE}" >> "${UNINSTALLLOG}" launchctl bootout system ${LAUNCHD_DAEMON_DIR}/${LAUNCHD_DAEMON_VPNAGENT_FILE} >> "${UNINSTALLLOG}" 2>&1 fi # Stop the AnyConnect VPN Service app echo "Stopping AnyConnect VPN Service..." >> "${UNINSTALLLOG}" logger "Stopping AnyConnect VPN Service..." osascript -e "quit app \\"${SERVICE_APP}\\"" pkill -x "${SERVICE_APP}" # Unregister services echo "Unregistering AnyConnect VPN Service..." >> "${UNINSTALLLOG}" logger "Unregistering AnyConnect VPN Service..." sudo -u \\#${MYUID} open -W -a "${BINDIR}/${SERVICE_APP}" --args uninstall # grep pattern to skip processes that shouldn't be considered as "Cisco Secure Client" related processes. SKIPPROCS="grep|installer|preinstall|vpn_uninstall|cisco_secure_client_uninstall|${UNINSTALLER}" # ensure that the agent, gui and cli are not running - show no mercy OURPROCS=`ps -A -o pid,command | egrep "vpnagentd|(${INSTPREFIX}/bin)|(Cisco Secure Client)" | egrep -v "${SKIPPROCS}" | awk '{print $1}'` if [ -n "${OURPROCS}" ] ; then for DOOMED in ${OURPROCS}; do echo Killing `ps -A -o pid,command -p ${DOOMED} | grep ${DOOMED} | egrep -v 'ps|grep'` >> "${UNINSTALLLOG}" kill -KILL ${DOOMED} >> "${UNINSTALLLOG}" 2>&1 done fi # Revert the system pf.conf file updates performed during install, unless this uninstall is part of an upgrade. if [ "x${IS_UPGRADE}" != "xtrue" ]; then echo "Reverting pf.conf changes" >> "${UNINSTALLLOG}" ${BINDIR}/acinstallhelper -pfConfUpdate -revert else echo "Skip reverting pf.conf changes during upgrade" >> "${UNINSTALLLOG}" fi # Remove the AnyConnect VPN Service app, unless this is part of an upgrade if [ "x${IS_UPGRADE}" != "xtrue" ]; then echo "rm -rf ${BINDIR}/${SERVICE_APP}" >> "${UNINSTALLLOG}" rm -rf "${BINDIR}/${SERVICE_APP}" >> "${UNINSTALLLOG}" else echo "Skip removing AnyConnect VPN Service app during upgrade" >> "${UNINSTALLLOG}" fi # Notify KDF upgrade start. # TODO: REVISIT ONCE THE KDF PACKAGE IS AVAILABLE. if [ "x${IS_UPGRADE}" = "xtrue" ]; then echo "Notifying KDF upgrade start" >> "${UNINSTALLLOG}" ${KDF_BINDIR}/acsocktool -us >> "${UNINSTALLLOG}" fi # unload the acsock if it is still loaded by the system ACSOCKLOADED=`kextstat | grep acsock` if [ ! "x${ACSOCKLOADED}" = "x" ]; then echo "Unloading {KEXTDIR}/acsock.kext" >> "${UNINSTALLLOG}" kextunload "${KEXTDIR}/acsock.kext" >> "${UNINSTALLLOG}" 2>&1 echo "${KEXTDIR}/acsock.kext unloaded" >> "${UNINSTALLLOG}" fi # The network extension KDF is installed regardless of OS version, but only used on macOS 10.16+. if [[ "$OS_VER_MAJOR" -ge 11 ]] || [[ "$OS_VER_MINOR" -ge 16 ]] ; then # Deactivate the network extension KDF if not upgrade. For upgrade, the KDF app will simply be # upgraded to avoid deactivation/activation approval prompts. if [ "x${IS_UPGRADE}" != "xtrue" ]; then ACSOCKEXTACTIVE=`systemextensionsctl list | grep acsockext` if [ ! "x${ACSOCKEXTACTIVE}" = "x" ]; then echo "Deactivating network extension acsockext" >> "${UNINSTALLLOG}" # Need to run as logged in user, as user needs to authorize the extension deactivation. sudo -u \\#${MYUID} "${APPDIR}/${NWEXT_KDF_APP}/Contents/MacOS/Cisco Secure Client - Socket Filter" -deactivateExt >> "${UNINSTALLLOG}" echo "Network extension acsockext deactivated" >> "${UNINSTALLLOG}" fi else echo "Skip deactivating of network extension acsockext during upgrade" >> "${UNINSTALLLOG}" fi fi # Remove the network extension KDF app. echo "rm -rf ${APPDIR}/${NWEXT_KDF_APP}" >> "${UNINSTALLLOG}" rm -rf "${APPDIR}/${NWEXT_KDF_APP}" >> "${UNINSTALLLOG}" # Remove only those files that are installed for AnyConnect VPN, # or are dependent on AnyConnect VPN being installed. # INDEX=0 while [ $INDEX -lt ${#FILELIST[@]} ] ; do echo "rm -rf "${FILELIST[${INDEX}]}"" >> "${UNINSTALLLOG}" rm -rf "${FILELIST[${INDEX}]}" let "INDEX = $INDEX + 1" done # Remove the kdf/lib directory if [ -e ${KDF_LIBDIR} ] ; then echo "rm -rf "${KDF_LIBDIR}"" >> "${UNINSTALLLOG}" rm -rf "${KDF_LIBDIR}" >> "${UNINSTALLLOG}" 2>&1 fi # Remove the kdf directory if it is empty if [ -e ${KDFDIR} ] ; then if [ ! -z `find "${KDFDIR}" -prune -empty` ] ; then echo "rm -df "${KDFDIR}"" >> "${UNINSTALLLOG}" rm -df "${KDFDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Since modules that are NOT dependent on AnyConnect VPN can be # present (even after VPN is uninstalled), remove the "plugins" # directory only if it is NOT empty. # if [ -e ${PLUGINDIR} ] ; then if [ ! -z `find "${PLUGINDIR}" -prune -empty` ] ; then echo "rm -rf "${PLUGINDIR}"" >> "${UNINSTALLLOG}" rm -rf "${PLUGINDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Remove Disable VPN Profile unless an upgrade is in progress if [ "x${IS_UPGRADE}" != "xtrue" ]; then echo "rm -rf \\"${PROFDIR}/VPNDisable_ServiceProfile.xml\\"" >> "${UNINSTALLLOG}" rm -rf "${PROFDIR}/VPNDisable_ServiceProfile.xml" fi # Remove the bin directory if it is empty if [ -e ${BINDIR} ] ; then if [ ! -z `find "${BINDIR}" -prune -empty` ] ; then echo "rm -df "${BINDIR}"" >> "${UNINSTALLLOG}" rm -df "${BINDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Only remove the Application directory if it is empty if [ ! -z `find "${APPDIR}" -prune -empty` ] ; then echo "rm -rf "${APPDIR}"" >> "${UNINSTALLLOG}" rm -rf "${APPDIR}" >> "${UNINSTALLLOG}" 2>&1 fi # Remove the lib directory if it is empty if [ -e ${LIBDIR} ] ; then if [ ! -z `find "${LIBDIR}" -prune -empty` ] ; then echo "rm -df "${LIBDIR}"" >> "${UNINSTALLLOG}" rm -df "${LIBDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Remove the script directory if it is empty if [ -e ${SCRIPTDIR} ] ; then if [ ! -z `find "${SCRIPTDIR}" -prune -empty` ] ; then echo "rm -df "${SCRIPTDIR}"" >> "${UNINSTALLLOG}" rm -df "${SCRIPTDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Remove the help directory if it is empty if [ -e ${HELPDIR} ] ; then if [ ! -z `find "${HELPDIR}" -prune -empty` ] ; then echo "rm -df "${HELPDIR}"" >> "${UNINSTALLLOG}" rm -df "${HELPDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Remove the management profile directory if it is empty if [ -e ${MGMTPROFDIR} ] ; then if [ ! -z `find "${MGMTPROFDIR}" -prune -empty` ] ; then echo "rm -df "${MGMTPROFDIR}"" >> "${UNINSTALLLOG}" rm -df "${MGMTPROFDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Remove the profile directory if it is empty if [ -e ${PROFDIR} ] ; then if [ ! -z `find "${PROFDIR}" -prune -empty` ] ; then echo "rm -df "${PROFDIR}"" >> "${UNINSTALLLOG}" rm -df "${PROFDIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # Remove the install directory/subdirectories if empty. if [ -e ${COMPONENT_DIR} ] ; then if [ ! -z `find "${COMPONENT_DIR}" -prune -empty` ] ; then echo "rm -df "${COMPONENT_DIR}"" >> "${UNINSTALLLOG}" rm -df "${COMPONENT_DIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi if [ -e ${DEPENDENCY_DIR} ] ; then if [ ! -z `find "${DEPENDENCY_DIR}" -prune -empty` ] ; then echo "rm -df "${DEPENDENCY_DIR}"" >> "${UNINSTALLLOG}" rm -df "${DEPENDENCY_DIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi if [ -e ${INSTALL_DIR} ] ; then if [ ! -z `find "${INSTALL_DIR}" -prune -empty` ] ; then echo "rm -df "${INSTALL_DIR}"" >> "${UNINSTALLLOG}" rm -df "${INSTALL_DIR}" >> "${UNINSTALLLOG}" 2>&1 fi fi # remove installer receipt pkgutil --forget ${CSC_VPN_PACKAGE_ID} >> "${UNINSTALLLOG}" 2>&1 echo "Successfully removed Cisco Secure Client from the system." >> "${UNINSTALLLOG}" echo "Successfully removed Cisco Secure Client from the system." exit 0
Hello,
Any update ?
I Have exactly the same problem
Regards
  • October 22, 2024
I get the same, yes. anyone found a fix?
  • October 22, 2024
I do this... https://docs.umbrella.com/umbrella-user-guide/docs/customize-macos-installation-of-cisco-secure-client
No prompt or anything and customize what gets installed. The scripting method, to me in this case, is not worth the effort.
  • October 22, 2024
To be clear, this is to install a current version, and it overwrite an older version automatically.
  • October 22, 2024
This was for uninstalling Cisco Secure Client.
However, i've added a command to disable System extension and now it works, it does it silently:
sudo '/Applications/Cisco/Cisco Secure Client - Socket Filter.app/Contents/MacOS/Cisco Secure Client - Socket Filter' -deactivateExt
sudo /opt/cisco/secureclient/bin/cisco_secure_client_uninstall.sh
Hope this will help others as well
  • April 7, 2025
You should be able to change the extension attribute for the system extension from Allowed System Extensions to Removable System Extensions. That will allow you to run the removal script via Jamf and it will remove the program without asking for admin rights to adjust the System Extension.  https://www.cisco.com/c/en/us/td/docs/security/vpn_client/anyconnect/Cisco-Secure-Client-5/admin/guide/b-cisco-secure-client-admin-guide-5-1/macos11-on-ac.html
I am still trying to figure out how to silently uninstall Cisco Secure Client - DART
  • April 7, 2025
Sorry, I said extension attribute, I should have said configuration profile.
  • April 8, 2025
DART can be silently uninstalled by running /opt/cisco/secureclient/bin/dart_uninstall.sh
mvu
  • April 8, 2025
What I use, in case it helps:
/opt/cisco/secureclient/bin/amp_uninstall.sh
/opt/cisco/secureclient/bin/iseposture_uninstall.sh
/opt/cisco/secureclient/NVM/bin/nvm_uninstall.sh
/opt/cisco/secureclient/bin/umbrella_uninstall.sh
/opt/cisco/secureclient/bin/zta_uninstall.sh
### Uninstall Duo Desktop and Duo Device Health
/Applications/Duo\\ Desktop.app/Contents/Library/LaunchServices/com.duosecurity.UninstallDuoDeviceHealth
/Applications/Duo\\ Device\\ Health.app/Contents/Library/LaunchServices/com.duosecurity.UninstallDuoDeviceHealth
### Uninstall ThousandEyes Agent
/Applications/Cisco/Cisco\\ Secure\\ Client\\ -\\ ThousandEyes\\ Endpoint\\ Agent.app/Contents/Resources/uninstall.sh
mvu
  • April 8, 2025
Forgot, that if you're updating to Cisco Secure Client 5.1.8.122, the Duo Desktop won't go away for me. So I dragged the package in Composer and deleted Duo Desktop, then re-packaged. Yes, you can do the XML way, but this worked for me too.
  • April 10, 2025
You have to add a Removable System Extension under "System Extensions" Menu.
TheITGuy69
  • December 19, 2025
Thank you for this script, we were looking for a script that uninstalled all the separate modules but cisco secure client which your script does. Works perfectly!
If anyone is looking for a script to also uninstall the cisco secure client, you will need to add this in the script above.
a_martin253
  • January 5, 2026
So what do you do if your Macs don’t have a dart_uninstall.sh script within /opt/cisco/secureclient/bin/?
And even if I did, the cisco_secure_client_uninstall.sh script that would call it isn’t either as shown here:
mvu
  • January 6, 2026
@a_martin253
Might be worth looking into this utility.
https://community.jamf.com/general-discussions-2/cisco-secure-client-repackager-57137
