Thanks for the reply, chaz. Thanks for showing me where the menu is to create the copies.
From a UI design perspective, seeing that menu is really hard.
Disclosure triangles normally point to the right if closed and down if they are opened.
The various profiles are already listed below the name of the Blueprint. The arrow is pointing down, which could be interpreted as the Profiles listed below are part of this blueprint hierarchy.
So for those familiar with the way disclosure triangles work, the list of Profiles already looks like the disclosed list under the Blueprint name.
In other places, the ellipsis round button is used to denote a menu.
So there is an inconsistency in the UI design. Menus are found both behind a disclosure triangle and ellipsis.
For menus that are on the top right, if you hover there is a pop up menu that briefly explains. So there is kind of a hint that there is something more. For the blueprint title, there are no hover menus. So there really is no clue that this is a menu, unless you click.
The duplication occurs when you are displaying the current blue print. The hierarchy above does have wide buttons to create a new templates. So one might start to expect that adding things comes from wide buttons on the top right.
Now that I've had a chance to critique this a bit more, my first impression would be to put a square button with ellipsis where the chevron is currently located. That should convey that there is a menu nearby...
