Enable SSH from Jamf for Specific User
  • September 24, 2019
  • 9 replies
  • 15 views
Hi there,
What would be the best/easiest way to enable SSH on a specific users' machine remotely, from Jamf?
thank you!
  • 108 replies
  • March 27, 2020
@scalar-its, I'm looking to do the same thing. Did you find out a way to do this?
russeller
Forum|alt.badge.img+15
  • 216 replies
  • March 29, 2020
Here are the basic commands that you could make a script out of. Please test this before deployment.
ssh_user="username_here"
# turn ssh on
systemsetup -setremotelogin on
# append user to ssh group
dseditgroup -o edit -a $ssh_user -t user com.apple.access_ssh
# restart ssh
launchctl unload /System/Library/LaunchDaemons/ssh.plist
sleep 5
launchctl load -w /System/Library/LaunchDaemons/ssh.plist
You could add some additional error handling like checking the membership of the ssh group by using something like:
check_ssh_group=$(dscl . -read /Groups/com.apple.access_ssh | grep GroupMembership | grep -o $ssh_user)
if [[ ! $check_ssh_group ]]; then
   echo "$ssh_user was not added to group"
   exit 1
Hopefully this will give you a head start in building your own script for your Macs. You might want to also reach out to the MacAdmins on Slack for more advice.
donmontalvo
Forum|alt.badge.img+36
  • 4293 replies
  • March 29, 2020
As @ssrussell recommended, some additional logic can help. Here's the script we use in Self Service:
# Confirm SSH is enabled, and that an ACL exists, and that $CURRENT_USER is allowed.
# 20200106 DM
# Variables
CURRENT_USER=$(python -c 'from SystemConfiguration import SCDynamicStoreCopyConsoleUser; import sys; username = (SCDynamicStoreCopyConsoleUser(None, None, None) or [None])[0]; username = [username,""][username in [u"loginwindow", None, u""]]; sys.stdout.write(username + "
# Functions
ENABLE_REMOTE_LOGIN()
CHECK_REMOTE_LOGIN()
    systemsetup -getremotelogin
CREATE_ACL()
    dseditgroup -o create -q com.apple.access_ssh && dseditgroup -o edit -a "$CURRENT_USER" -t user com.apple.access_ssh
BOUNCE_REMOTE_LOGIN()
    launchctl unload -w /System/Library/LaunchDaemons/ssh.plist && launchctl load -w /System/Library/LaunchDaemons/ssh.plist
CHECK_MEMBERSHIP()
    dseditgroup -o checkmember -m "$CURRENT_USER" com.apple.access_ssh
# Commands
if [[ "CHECK_REMOTE_LOGIN" == "Remote Login: On" ]]
then
    echo "Remote Login is enabled, allowing $CURRENT_USER."
    CREATE_ACL
    echo "Bouncing Remote Login."
    BOUNCE_REMOTE_LOGIN
    sleep 5
    echo "Confirming Remote Login is enabled."
    CHECK_REMOTE_LOGIN
    echo "Confirming ACL membership."
    CHECK_MEMBERSHIP
    echo "Remote Login is disabled, enabling."
    ENABLE_REMOTE_LOGIN
    sleep 5
    if [[ CHECK_REMOTE_LOGIN = "Remote Login: On" ]]
    then
        CREATE_ACL
        BOUNCE_REMOTE_LOGIN
        sleep 5
        CHECK_REMOTE_LOGIN
        echo "Confirming $CURRENT_USER is allowed."
        CHECK_MEMBERSHIP
        echo "There was a problem enabling Remote Login."
        exit 1
  • 108 replies
  • March 30, 2020
Does anyone know off hand if an SSH user is added to a computer if it will wipe any users that are on there already? In my environment (HigherEd) we have Computer Science folks that may already have an SSH connection to a machine. I want to make sure it won't break that connection off.
donmontalvo
  • 4293 replies
  • March 30, 2020
The dseditgroup -o edit -a "$CURRENT_USER" -t user com.apple.access_ssh command appends to the ACL.
Would test of course.
pete_c
  • 255 replies
  • March 30, 2020
@joethedsa all you're doing is allowing or preventing a user from logging in via SSH. You're not actively adding or removing user accounts.
adam_macy1
  • 6 replies
  • June 1, 2020
com.apple.access_ssh has changed to com.apple.access_remote_ae
  • 67 replies
  • March 12, 2021
SSH ACL on 10.14 - 10.16:
dseditgroup -o edit -a "USER" -t user com.apple.access_ssh
Restart the ssh daemon:
launchctl kickstart -k system/com.openssh.sshd
com.apple.access_remote_ae is the ACL for Remote Apple Events (not needed).
  • March 25, 2025
The groups com.apple.access_ssh and com.apple.access_remote_ae serve different purposes:
  • com.apple.access_ssh: This group is used to manage access to the SSH service on a Mac. Users added to this group are allowed to log in remotely via SSH.
  • com.apple.access_remote_ae: This group is used to manage access to Remote Apple Events. Users in this group can send Apple events to the Mac from other computers, which can be useful for remote automation tasks.
    If the goal is to enable SSH access, you should use com.apple.access_ssh. If you need to enable remote Apple events for automation purposes, then com.apple.access_remote_ae is the appropriate group.
Cookie policy
Cookie settings
