Extension Attribute Help Finding Open Directory Binding
  • January 4, 2013
  • 0 views
I need to be able to find what open directory each computer is bound to. I think the only way is to create an extension attribute to pull it with inventory. I want to use this information to eventually re-bind some machines to their building specific OD.
1 reply
Forum|alt.badge.img+31
  • 920 replies
  • January 4, 2013
In a bit of serendipity, Sonic84 just posted an extension attribute for AD that (with very minor editing), you could use for OD:
https://jamfnation.jamfsoftware.com/discussion.html?id=6253
This extension attribute should show the OD server that particular machines are bound to:
result="`dscl /Search -read / | grep "/LDAPv3/" | sort -u`"
Cookie policy
Cookie settings
