how to enable the set time zone automatically using your current location radio button on system set
Hi, I want to enable set time zone automatically using your current location radio button on system settings for all my org Mac on bulk. How do we get it, I want all the Mac date and time settings to be like it is on this image.
Best answer by cdev
AJPinto wrote:
This would require location services which you cannot force enable for a user. I don't think what you are asking is possible. However, the time zone can be set with a script. You can work something out in JAMF to set time zones with a policy.
#!/bin/sh #-------------------------------------------------------- # Set the Mac timezone & timeservers #-------------------------------------------------------- # Set the timezone systemsetup -settimezone "$4" # Set the timezone to regions internal time server /usr/sbin/systemsetup -setnetworktimeserver 10.255.216.19 # The below command will list all available timezones # systemsetup -listtimezones
Give this a shot:
uuid=$("/usr/sbin/system_profiler" SPHardwareDataType | grep "Hardware UUID" | awk '{ print $3 }')
timedPrefs="/private/var/db/timed/Library/Preferences/com.apple.timed.plist"
dateTimePrefs="/private/var/db/timed/Library/Preferences/com.apple.preferences.datetime.plist"
locationPrefs="/private/var/db/locationd/Library/Preferences/ByHost/com.apple.locationd.${uuid}"
byHostPath="/var/db/locationd/Library/Preferences/ByHost/com.apple.locationd"
# Set preferences.
echo "Ensuring location services are enabled"
sudo -u "_locationd" /usr/bin/defaults -currentHost write "$locationPrefs" LocationServicesEnabled -int 1
sudo defaults write "${byHostPath}" LocationServicesEnabled -int 1
/usr/sbin/chown "_locationd:_locationd" "$locationPrefs"
echo "Configuring automatic time"
/usr/bin/defaults write "$timedPrefs" TMAutomaticTimeZoneEnabled -bool YES
/usr/bin/defaults write "$timedPrefs" TMAutomaticTimeOnlyEnabled -bool YES
/usr/bin/defaults write "$dateTimePrefs" timezoneset -bool YES
/usr/sbin/chown "_timed:_timed" "$timedPrefs" "$dateTimePrefs"
AJPinto
  • 2758 replies
  • November 6, 2023
cdev
  • 135 replies
  • November 6, 2023
Give this a shot:
# Set preferences.
  • 4 replies
  • November 7, 2023
cdev wrote:
Give this a shot:
# Set preferences.
Hi @cdev , Tried running the script on macOS Sonoma but getting this error
  • 4 replies
  • November 7, 2023
is there something we need to change based on the OS
cdev
  • 135 replies
  • November 7, 2023
I’ve had good luck with that script as is running on Sonoma Macs, including enabling location services. Sometimes it’s taken a reboot for the settings to fully apply, but most of my runs have worked within 2 minutes.
  • 4 replies
  • November 7, 2023
hi @cdev gotcha!!! the restart does the trick, Thanks!!!!!!
JevermannNG
  • 136 replies
  • September 23, 2024
I get the same error running the script on macOS 15.0
We are looking for a similar script that sets the Time Zone for out Virtual Machines because for some unknown reason, they dont fetch the correct zone during Enrollment.
  • September 24, 2024
Hi Jevermann,
We use the following:
#!/bin/zsh # # Daniel Angeloni 2024 # # Sets timezone and region # timezone="Australia/Sydney" region="AU" # Set the timezone systemsetup -settimezone "$timezone" if [ $? -eq 0 ]; then echo "Timezone set to $timezone" else echo "Failed to set timezone" >&2 exit 1 fi # Set the region defaults write NSGlobalDomain AppleLocal en_"$region" if [ $? -eq 0 ]; then echo "Region set to $region" else echo "Failed to set AppleLocal" >&2 exit 1 fi defaults write NSGlobalDomain AppleLocale en_"$region" if [ $? -eq 0 ]; then echo "Region set to $region" else echo "Failed to set AppleLocale" >&2 exit 1 fi defaults write NSGlobalDomain OSLocale en_"$region" if [ $? -eq 0 ]; then echo "Region set to $region" else echo "Failed to set OSLocale" >&2 exit 1 fi defaults write NSGlobalDomain region "$region" if [ $? -eq 0 ]; then echo "Region set to $region" else echo "Failed to set region" >&2 exit 1 fi defaults write com.apple.dock region "$region" if [ $? -eq 0 ]; then echo "Region set to $region" else echo "Failed to set region" >&2 exit 1 fi defaults write NSGlobalDomain loc en_GB:"$region" if [ $? -eq 0 ]; then echo "Region set to $region" else echo "Failed to set loc" >&2 exit 1 fi # Apply the changes echo "Timezone and region settings applied successfully." killall SystemUIServer exit 0
Let us know how you go.
Hamish.
Aronjlove
  • December 11, 2024
cdev wrote:
Give this a shot:
# Set preferences.
This script still works on 15.2 as of the date of this post. Thanks!
Does this script prevent the user from disabling the automatic toggle?
Cookie policy
Cookie settings
