Java 7 u17 - Disable Check for Updates Automatically
  • March 15, 2013
  • 0 views
I have a specific need to disable the Check for Updates Automatically in the Java Control Panel across multiple computers. I can successfully build the plist/dmg and distribute it via Casper. However, when the Java control panel is opened, the control panel resets the setting and enables Check for Updates Automatically. Any thoughts?
Best answer by recobbs
Never mind, just found info post by andrew_stenehjem... Will take a look at that...
  • March 15, 2013
Cookie policy
Cookie settings
