CocoaDialog would work great in this scenario. We're doing something similar in DeployStudio with CD, thanks to @rustymyers I've started expanding options thanks to user input of CD.
Good example to get started with LINKY
I use osascript in my scripts so I don't have to also install CocoaDialog. It's a bit more limited, but usually meets my needs. Here's an example:
usernamePrompt(){
su - "${loggedInUser}" -c osascript <<EOT
with timeout of 8947848 seconds
text returned of (display dialog "$2" default answer "$3" buttons {"OK"} default button 1 with title "$1" with icon caution)
end timeout
end tell
EOT
username="$(usernamePrompt 'Enter Username' 'Please enter the username you would like to modfy.' 'enter username')"
Maybe this will help? I use it to prompt for a username, then assign the user to a device during enrollment when using a custom QuickAdd package.
CD="/Library/Application Support/JAMF/bin/cocoaDialog.app/Contents/MacOS/cocoaDialog"
rv=($("$CD" standard-inputbox --title "Username" --no-newline --informative-text "Enter the username of the user assigned to this machine (firstname_lastname)" --value-required))
USER=${rv[1]}
jamf recon -endUsername $USER
tb=`"$CD" ok-msgbox --text "User Added!"
--informative-text "The computer's associated user has been set to $USER."
--no-newline --float`
if [ "$tb" == "1" ]; then
echo "User said OK"
elif [ "$tb" == "2" ]; then
echo "Canceling"
exit
@millersc @emily Thanks I will give your suggestions with cocoa a try if I cant get it going with osascript! @mbezzo Think I am pretty close now with your suggestion. probably an easy fixing but the username I am getting, its not passing as a variable and copying the respective folder.
username=$(/usr/bin/osascript<<END
activate
set the answer to text returned of (display dialog "What username do you want to rynsc?" default answer "" buttons {"Continue"})
end tell
END)
echo "Remove user home folder cache..."
sleep 1
rm -rf /Volumes/Macintosh HD 1/Users/"username"/Library/Caches/*
sleep 2
echo "Emptying user Trash..."
rm -rf /Volumes/Macintosh HD 1/Users/"username"/.Trash/*
sleep 2
sleep 1
echo "Working..."
sleep 1
echo "Initializing Migration Assistant..."
sleep 2
echo "Transferring User Data....."
sleep 1
/usr/bin/rsync -av /Volumes/Macintosh HD 1/Users/"username"/* /Volumes/Macintosh HD/Users/"username"/
sleep 2
echo "Running Transferring User Data......"
sleep 1
sleep 1
echo "Working..."
sleep 2
echo "Running Transferring User Data..........."
sleep 1
echo "Adjusting File Permissions..."
/usr/bin/chmod -R 775 /Volumes/Macintosh HD/Users/"username"
sleep 1
echo "Adjusting File Ownership..."
/usr/sbin/chown -R "username":staff /Volumes/Macintosh HD/Users/"username"
echo "Copy complete..."
sleep 1
echo "Transfer Completed Successfully..."
I'm not a scripting expert by any means, but I'm guessing it's because you have it in the filepaths as "username"
rather than $username
or however else the variable is being defined.
@TomDay In all instances in your script you aren't using "username" as a variable. Its just a string. For example:
needs to be:
rm -rf /Volumes/Macintosh HD 1/Users/"$username"/Library/Caches/*
Note the $ sign on username to make it into a variable.
@emily @mm2270 Thanks, works perfectly now using a variable! How did I miss that, even as a scripting newb! Just need to clean it up a bit.
I like CocoaDialog for prompting because it offers a pretty easy way to slip in variables. Here's a quick example that I would start from to add the function for choosing a user home. I prefer to ask which user, rather than expect the person to enter the correct Username:
for i in /Users/*; do
myUsers=($i ${myUsers[*]})
done
echo $myUsers
userResponse=$(/Users/rzm102/Desktop/CocoaDialog.app/Contents/MacOS/CocoaDialog standard-dropdown --items ${myUsers[*]})
echo "$userResponse"
read returnvalue userselection <<< $userResponse
echo "Return code: $returnvalue"
echo "User Selected: ${myUsers[$userselection]}"
Using that before your code to set the path to the user folder you'd like to back up.
This is also the purpose of the BackupRestore scripts, which just got the ability to prompt for the user to back up. https://github.com/rustymyers/BackupRestore
Hope that helps!
Rusty
The osascript function worked perfectly. Simple yet perfectly effective.
Thanks to Everyone that joined the conversation. It's become very clear that I need to experiment with CocoaDialog!
-Tom
