you've got a lot going on. I suggest you break it down into smaller parts to isolate. If you're getting a flashing folder with a question after putting down an OS X image, you need to resolve that first, before you look at the other applications. Either that base OS X image didn't actually put down anything onto the drive, or it's not bootable.
This line indicates you want to install a clean OS - "Installing OSX10.10.5AutoDMG20082015.dmg"
But what is not shown is the log that you've selected to erase the drive first. Without erasing the drive, it can lead to a combo of the OS that is already there on the drive and the some parts of the OS that come from AutoDMG. This can lead to a non-booting Mac.
I suspect all will go well if you set CI to Erase target drive.
@jhalvorson Yes that was one without Casper Imaging erasing the target drive but I have tried several times with erasing the drive as well (log below) but still the same thing at the end following boot up - a big folder with a question mark. What is the best way to proceed - do the AutoCasperNBI again or try with a different OS X base image in the configuration or something else?
Initializing Imaging Process...
Mounting sscvlqmljds001...
Mounting https://sscvlqmljds001/CasperShareDAV/...
Preparing disk for block copy...
Performing Block Copy of OSX10.10.5AutoDMG20082015.dmg...
Cleaning up after block copy...
Erasing Macintosh HD...
Installing OSX10.10.5AutoDMG20082015.dmg...
Installing Bit9_AgentDisabled_7.2.1.1101_09Sept15.dmg...
Error: The file Bit9_AgentDisabled_7.2.1.1101_09Sept15.dmg could not be opened. Please verify the permissions.
Installing CarbonBlack_4.2.7.50624_10Sept15.dmg...
Error: The file CarbonBlack_4.2.7.50624_10Sept15.dmg could not be opened. Please verify the permissions.
Installing CentrifyExpressDC5.2.3_20072015.dmg...
Installing GoogleChrome_21072015.dmg...
Installing GPVPN-2.2.0-48_01092015.dmg...
Installing Lync_Mac14.1.1_01Sept2015.dmg...
Installing MSOffice2016_15.13.1_01Sept15.dmg...
Setting computer name to "NewCasperTestMac02"...
Creating /private/etc/jamf.conf...
Creating /usr/sbin/jamf...
Creating jamfHelper...
Ensuring Apple's Setup Assistant does not appear...
Creating First Run Enroll Script...
Creating First Run Post Install Script...
Adding line to Fix ByHost Files...
Adding line to run Disbale iCloud/Diagnostics Prompt...
Adding line to run Enable ScreenSharing...
Adding line to run Set TimeZone
Copying script Set TimeZone
Downloading Disbale iCloud/Diagnostics Prompt...
Copying script Disbale iCloud/Diagnostics Prompt...
Downloading Enable ScreenSharing...
Copying script Enable ScreenSharing...
Downloading Set TimeZone
Ensuring system files are hidden...
Unmounting Distribution Point...
Blessing System...
@Hafiz if you use Disk Copy to put down the base OS that you created with AutoDMG are you able to get the computer to boot up normally? If you're not, then there is likely something wrong with your base OS. I would first verify that the base OS you are using is working normally before adding Casper Imaging to the mix.
@mpermann Okay I switched to using the File Share Distribution Point (an afp share) and now imaging works for the force trackpad Macs, I am assuming from that that the base OS X is fine and something is wrong with Casper Imaging when using the JDS share.
Also, I don't understand why the older Macs are not even seeing the netboot service when pressing the option key whilst the new force trackpad Macs can at boot-up so I am going to redo the netboot set with AutoDMG and AutoCasperNBI and hope they start seeing it.
@Hafiz we have some models that will not show our NetBoot server when holding down the Option key as well. On those older computers we're forced to either use the N key on startup to boot to the default NetBoot image or boot from an external drive and choosing the specific NetBoot set we want to boot to from the Startup Disk System Preference pane. I've read in other threads where people have had problems imaging from JDSes so we've avoided them. The standard distribution has worked well for us so we haven't felt the need to add any JDSes to the mix.
@mpermann I just tried holding down the N key and it isn't able to netboot with that key pressed down. How are you setting up the external hard drive for netbooting? We are an international company and I want to deploy Casper Imaging via netboot/netinstall to the rest of the offices and I thought the only way to do that was to deploy JDS's to the rest of the international offices. So can I just deploy File Share Distribution Points to the rest of the offices instead? If that is the case then I don't understand the need for JDS's whatsoever.
@Hafiz the external bootable drive is just used to select the NetBoot set from the Startup Disk System Preference pane then we restart the computer to boot it from the NetBoot server. In some instances we want to NetBoot computers from a NetBoot set other than the default one. So on those older computers that don't allow selecting the NetBoot server using the Option key we're forced to use the external bootable drive to facilitate this. You can just deploy a normal distribution point rather than the JDSes in your other offices. We don't utilize any JDSes at all. I believe there are other organizations that don't utilize them as well. What kind of hardware were you planning to deploy in your other offices?
@mpermann The older Macs can't see the NetBoot set even from the Startup Disk System Preference pane so that won't help either. So what really is the point of a JDS and adding it into the JSS? The hardware in the other offices will also just be MacBooks.
@Hafiz are the older MacBooks on the same subnet as the other MacBooks that you are able to image successfully? The manual says that a JDS is "A JAMF Distribution Server (JDS) instance is a distribution point that is managed by the JAMF Software Server (JSS), similar to a computer or mobile device. It can be used to host packages, in-house apps, and in-house eBooks." If you check out the attached images you'll see a good explanation of the different distribution points that Casper supports and what they can do.
@mpermann Yes, the older Macs and the newer Macs are on the exact same subnet established by a dhcp server. I am going to set-up a new NBI using AutoDMG and AutoCasperNBI and push that onto the CentOS 7 JDS. Thanks for the info - I can see that the advantage of the JDS compared to a normal distribution point is that the non-root JDS instances have replication immediately. If I can get the old Macs to able to see the netboot server then I would feel fine about continuing with just a normal distribution point.
@Hafiz what are you hosting your NetBoot server on? Our NetBoot server is hosted on a Mac Mini with Mac OS 10.10.5 and Server 4.1.5. Our nbi set was created with AutoCasperNBI using an OS created by AutoDMG and we've not had any issues NetBooting our systems.
@mpermann I am using CentOS 7, we don't want to host enterprise infrastructure across a stack of Mac Mini's. Hence, the need to use CentOS 7. Below is how I configured and got the Netboot server to work on CentOS 7, it does work but as I say is not being picked up by the older MacBooks (pre-force trackpad).
Ref:
https://themacwrangler.wordpress.com/2015/04/24/creating-a-netboot-server-with-centos-7-and-bsdpy/comment-page-1/#comment-113
https://macmule.com/projects/autocaspernbi/
http://www.projectatomic.io/blog/2015/06/notes-on-fedora-centos-and-docker-storage-drivers/
Use AutoDMG to create a never booted DMG of the latest OS with Updates.
AutoCasperNBI application settings:
Netboot Name: 10.10.5AutoCasperNBI
Tick “Will be served from NetSUS or BSDPy"
Make sure to tick “Install modified rc.netboot file"
This netboot server uses containers to boot from.
$ yum -y update
$ systemctl stop firewalld && systemctl disable firewalld
$ sed -i -e 's/SELINUX=enforcing/SELINUX=disabled/g' /etc/selinux/config
$ reboot
$ yum -y install vim docker
$ systemctl start docker
$ systemctl enable docker
$ systemctl restart docker
$ docker pull hunty1/bsdpydocker
$ rm -rf /var/lib/docker/
$ vim /etc/sysconfig/docker-storage
And amend to the following:
DOCKER_STORAGE_OPTIONS= -s overlay
run “docker info” to verify that Storage Driver is now called overlay.
$ mkdir /nbi
$ docker run --restart=always -d -v /nbi:/nbi -p 69:69/udp -p 67:67/udp -p 80:80 -e BSDPY_IP=10.204.132.116 --name netboot_server hunty1/bsdpydocker
verify that docker container is running “docker ps -a"
look at docker logs for container: “docker logs -f netboot_server"
$ yum -y install samba samba-client
$ useradd smmbuser
$ smbpasswd -a smbuser
$ useradd smbuser
$ mv /etc/samba/smb.conf /etc/samba/smb.conf.backup
$ vim /etc/samba/smb.conf
Minimal SMB Conf file for CentOS 7
[global]
workgroup = MYGROUP
server string = Samba Server Version %v
log file = /var/log/samba/log.%m
max log size = 50
security = user
passdb backend = tdbsam
local master = no
create mask = 0744
force create mode = 0744
directory mask = 0755
force directory mode =0755
inherit permissions = yes
============================ Share Definitions ==============================
[nbi]
path = /nbi
available = yes
read only = no
browseable = yes
public = no
writable = yes
$ systemctl start smb
$ systemctl start nmb
$ systemctl enable smb
$ systemctl enable nmb
$ chown smbuser /nbi
Copy netboot image set to /nbi, by copying across to the .nbi directory to netboot server /nbi directory
$ docker restart netboot_server
verify by running “docker logs netboot_server"
09/09/2015 04:15:47 PM - DEBUG: [========= Updating boot images list =========]
09/09/2015 04:15:47 PM - DEBUG: Considering NBI source at /nbi/10.10.5AutoCasperNBI.nbi
09/09/2015 04:15:47 PM - DEBUG: /nbi/10.10.5AutoCasperNBI.nbi
09/09/2015 04:15:47 PM - DEBUG: [========= End updated list =========]
09/09/2015 04:15:47 PM - DEBUG: [========= Using the following boot images =========]
09/09/2015 04:15:47 PM - DEBUG: [========= End boot image listing =========]
@Hafiz sorry CentOS isn't something I've used so I can't be of any assistance with it. We've always used Mac OS based systems with our JSS infrastructure. We're pretty small with only around 800 Macs and 650 iPads so the Mac Minis have worked just fine for our setup. Hopefully someone with some CentOS experience will chime in on what might be causing your issue.
Older MacBooks and iMacs will not see a NBI if it was builded in 10.10. Create a new NBI in 10.8 or lower for this to work.
I have the same problem with my Early 2007 iMacs and MacBook Pro's after I placed the new NBI that I made in 10.10 in own netboot server. I didn't delete the old NBI, I turned it off, once I turned it back on, I could netboot again.
Create your own NBI using System Image Utility :
10.8 or Lower
System Image Utility Location - /System/Library/CoreServices
Steps - https://www.apple.com/support/osxserver/systemimaging/
@Hafiz take a look at this Apple technote regarding building a NetBoot image that supports multiple models. Depending upon the age of the computers you are trying to NetBoot you may in fact need more than one nbi set.
@mblair Thanks! Tried 10.10.3 nbi set and that is also not being seen by the older MacBooks. Where do you get your 10.8 OS X app to make into a dmg with AutoDMG? I think the Apple Store only has the latest OS X app.
I think the problem with the System Image Utility is that it will create an nbi set but that won't have Casper Imaging installed whereas the method of using AutoCasperNBI creator adds that in as well as other configuration options. Does anyone know if I can use 10.8 OS X with AutoCasperNBI ? Cheers.
@bentoms Are you the creator of AutoCasperNBI ? Could you respond if you are around. Thanks
@Hafiz what is the specific model of the MacBook that you are having problems NetBooting?
@Hafiz if a user has an Apple ID that had 10.8 downloaded before the new OS X was released, it should show up in AppStore/Purchased. However if they/you have a Mac that is running 10.8, just duplicate it with Casper Composer by making a image and placing Casper Imaging to AutoRun when the system startup. (Best to do this as ROOT)
http://osxdaily.com/2014/02/24/re-download-older-os-x-version-from-mac-app-store/
Steps:
Install 10.8
Login as ROOT and set to AutoLogin
Set Casper Imaging to AutoStart
Test if it works when restart
Use Target mode to create in NBI with System Image Utility from another computer
Or (More Technical) Split partition, and install 10.8 on the second partition that is blank, than create NBI.
Hope this helps.
@mblair @mpermann Guys I think this is to do with the netboot service itself not being picked up, rather than netboot/netinstall failing. The older MacBooks are simply not seeing the service when the option key is pressed or in Startup Disk when they running Mac OS X. What could cause the service simply not being seen?
what is the model of macbook that is not working
specifically provide the model identifier ie macbookpro8,1
Do other machines on the same network work? can you take say a new iMac or MacBook Pro and plug it into the same ethernet cable as the MacBook's that are not working and test if they will see the netboot server and boot from it?
@calumhunter It is the MacBook model just before the force trackpad came out (at home so not sure what the model number was for that). Yes, I am using the same ethernet cable and network for the Macs. Force trackpad models see the netboot server but the ones before that model don't. Really bizarre, must be something to do with the way the network stack is implemented on the older Macs.
@Hafiz check out this article
on how to identify different MacBook Pro models. This article
talks about EFI and SMC firmware updates for computers. You might want to verify that the firmware on the model you are having problems with is up to date. If the firmware is up to date and the model identifier is MacBookPro11,1 you should be able to hold down the option key and see a properly configured NetBoot server. We have 176 of that model and we don't have any problems NetBooting that model.
Posted: Today at 5:07 PM by Hafiz
Something is up with your setup for sure.
I have a 10.10.5 14F27 NetBoot image created with AutoDMG -> AutoCasperNBI and I can boot anything from 2009 Unibody MacBooks through to 2015 Retina MacBook Pros
@Hafiz AutoCasperNBI can create 10.7+ NBI's. But only on 10.9+ (I'll need to amend this)
Macs should be able to boot to any NBI created from an OS that they will boot too.
So if the Mac supports 10.10.5, then a 10.10.5 NBI should work.
Is there any model filtering on your NBI?
There's 2 issues here right? 2nd being the blinking globe post imaging the trackpad Macs??
As @calumhunter said.. We have 2009 & up macs booting to 10.10.5 fine.
