Programmatically "reset printing system" via command line
Show first post
johntgeck
  • 44 replies
  • February 8, 2023
erik_crouch wrote:
This has stopped working on Ventura sadly... it's getting Killed:9 either when Jamf runs it, or even me with sudo.  Trying to find some solutions, but running into this still.
Some logs for good measure, we have a policy that resets printing system and then adds lab printers in a computer lab.
Executing Policy Mabpool Drivers and Queue Reset
Running script Reset Printing System...
Script exit code: 137
Script result: /Library/Application Support/JAMF/tmp/Reset Printing System: line 2: 72478 Killed: 9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/printtool --reset -f
Error running script: return code was 137.
Any thoughts or suggestions are helpful!
Imagine the pain I feel at discovering this right *after* I finished upgrading a lab to Ventura. ðŸ˜­
lmk if you find any solutions to this.
stevewood
Forum|alt.badge.img+35
  • 1798 replies
  • February 13, 2023
Are you running just the printtool command when you run it manually, or are you trying to run an entire script? I was able to run the printtool command on my macOS 13.2 device both with sudo and without and did not receive any errors.
I would look at your overall script. The error states it is failing at line 2. What is line 2 in the script?
  • 6 replies
  • February 13, 2023
Hey, thanks for getting back!  Line 2 is as follows...
EDIT:
I was running it as part of a script, and it was getting killed 9 in the script and when I ran it manually as sudo... but I just tried it on a system that has 13.2, and it did not kill it.  I'll try it again via the script and see what happens... maybe Apple fixed something?
  • 6 replies
  • February 13, 2023
Sure enough, it is working now... it must have been broken in 13.1 as that is when I was noticing the printer lists weren't getting cleared as intended.
@johntgecklooks like this is working now, my script is very simple and it as follows.  It looks like it requires 13.2 to work correctly, as it was failing before.
#/bin/sh
johntgeck
  • 44 replies
  • March 23, 2023
#/bin/sh
Sorry I am just getting back to this now, but I appreciate you tagging me! I'll give this a shot. :)
Cookie policy
Cookie settings
