SCRIPT FOR APPLICATION USAGE in the device in SMART GROUP
Hasibravo
I found this script very useful and extracting the list of application usage in the Smart Group.
#!/bin/bash # This script uses the api to gather all serial numbers of a computer group and then gathers application usage data for that mac. # each entry contains User data so, multiple lines will exist for each serial. one for each application. # exported report is stored in a coma sperated spreadsheet. # Please see end of script for terms ### # Environment Specific Variables can be left blank if passing parameters from jamf ### # hardcode here for testing api_user="" api_pass="" jamf_url="" # A Jamf Pro computer group (static or smart) that contains the client for which you want a report group_name='' # Number of days in report (using today as the end date...) days= # Check for passed parameters from jamf if [ "$4" != "" ]; then api_user=$4 fi if [ "$5" != "" ]; then api_pass=$5 fi if [ "$6" != "" ]; then jamf_url=$6 fi if [ "$7" != "" ]; then group_name=$7 fi if [ "$8" != "" ]; then days=$8 fi # Location of jamfHelper jamfHelper="/Library/Application Support/JAMF/bin/jamfHelper.app/Contents/MacOS/jamfHelper" # For testing only if you have a test JSS with a self signed SSL cert... # Set security='' for normal use. Set security='--insecure' for testing security='' #security='--insecure' # URL encode function urlencode() { old_lc_collate=$LC_COLLATE LC_COLLATE=C local length="${#1}" for (( i = 0; i < length; i++ )); do local c="${1:i:1}" case $c in [a-zA-Z0-9.~_-]) printf "$c" ;; *) printf '%%%02X' "'$c" ;; esac done LC_COLLATE=$old_lc_collate } # URL encode the group name group_name=$( urlencode "$group_name" ) # Pretty file name filename="Application Usage Report - $days day " # Today's date minus the days start_date=$(date -j -v-${days}d +"%Y"-"%m"-"%d") # Today's date end_date=$(date +"%Y-%m-%d") # Timestamp for filename timestamp=$(date +"%Y-%m-%d-%H%M%S") # Getting the Bearer token jamfTokenCurl=$(curl -s -u "$api_user:$api_pass" "$jamf_url/api/v1/auth/token" -X POST) jamfBearerToken=$(echo "$jamfTokenCurl" | jq -r .token) # If you want, this dialog box will let the user know what's about to happen buttonClicked=$("$jamfHelper" \\ -windowType utility \\ -title "Application Usage Report" \\ -heading "Please click OK to build the report." \\ -description "This process may take a few minutes depending on how many computers are in the report. We'll let you know when we're finished." \\ -button1 "Okay" \\ -defaultButton 1 \\ -icon "/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/AlertNoteIcon.icns") # Build the API path to the smartgroup api_path="JSSResource/computergroups/name/${group_name}" # Get the currently logged in user for the output file path loggedInUser=$(scutil <<< "show State:/Users/ConsoleUser" | awk '/Name :/ { print $3 }') loggedInUserHome=$(dscl . read /Users/$loggedInUser NFSHomeDirectory | cut -d' ' -f2-) # Getting Serial Numbers echo "Getting a list of devices in Jamf Pro group. " URL="${jamf_url}/${api_path}" responseXML=$(curl ${security} --silent --show-error --write-out "\\n%{http_code}" \\ --header "Authorization: Bearer ${jamfBearerToken}" \\ --header "Accept: text/xml" "${URL}") HTTP_Status=$(echo "$responseXML" | tail -1) responseXML=$(echo "$responseXML" | sed \\$d) echo "HTTP_Status : $HTTP_Status" /bin/echo -n "HTTP Status Code: $HTTP_Status : " if [[ $HTTP_Status = "200" ]]; then echo '[OK]' elif [[ $HTTP_Status = "400" ]]; then echo "[error] Invalid API request" exit 1 else echo "[error] API could not return the group information. " echo "$responseXML" exit 1 fi serialnumbers=($(echo "$responseXML" | xsltproc /tmp/stylesheet.xslt -)) echo "Serial number list : ${serialnumbers[@]}" device_count=${#serialnumbers[@]} touch /tmp/export.csv # Write the header values of each column echo "Full Name,Username,Position,Department,Building,Room,Email Address,Model,Serial Number,App Name,Version Number,Minutes in Forground,Minutes Open" > /tmp/export.csv for serial in "${serialnumbers[@]}"; do echo "Requesting details for device serial number : ${serial}" api_device_path="JSSResource/computers/serialnumber/$serial" location_data=$(curl ${security} --silent --show-error \\ --header "Authorization: Bearer ${jamfBearerToken}" \\ --header "Accept: text/xml" "$jamf_url/$api_device_path") username=$(echo $location_data | /usr/bin/awk -F'<username>|</username>' '{print $2}') realname=$(echo $location_data | /usr/bin/awk -F'<realname>|</realname>' '{print $2}') email_address=$(echo $location_data | /usr/bin/awk -F'<email_address>|</email_address>' '{print $2}') position=$(echo $location_data | /usr/bin/awk -F'<position>|</position>' '{print $2}') department=$(echo $location_data | /usr/bin/awk -F'<department>|</department>' '{print $2}') room=$(echo $location_data | /usr/bin/awk -F'<room>|</room>' '{print $2}') building=$(echo $location_data | /usr/bin/awk -F'<building>|</building>' '{print $2}') model=$(echo $location_data | /usr/bin/awk -F'<model>|</model>' '{print $2}') echo "\\$username : \\"${username}\\"" echo "\\$realname : \\"${realname}\\"" echo "\\$email_address : \\"${email_address}\\"" echo "\\$position : \\"${position}\\"" echo "\\$department : \\"${department}\\"" echo "\\$room : \\"${room}\\"" echo "\\$building : \\"${building}\\"" echo "\\$model : \\"${model}\\"" api_path="JSSResource/computerapplicationusage/serialnumber/$serial/${start_date}_${end_date}" xmlResponse=$(curl ${security} --silent --show-error \\ --header "Authorization: Bearer ${jamfBearerToken}" \\ --header "Accept: text/xml" "$jamf_url/$api_path") cat << EOF > /tmp/stylesheet.xslt <?xml version="1.0" encoding="UTF-8"?> <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform"> <xsl:output method="text"/> <xsl:template match="/"> <xsl:for-each select="computer_application_usage/usage/apps/app"> <xsl:text>${realname//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${username//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${position//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${department//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${room//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${building//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${email_address//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>${model//,}</xsl:text> <xsl:text>,</xsl:text> <xsl:text>$serial</xsl:text> <xsl:text>,</xsl:text> <xsl:value-of select="name"/> <xsl:text>,</xsl:text> <xsl:value-of select="version"/> <xsl:text>,</xsl:text> <xsl:value-of select="foreground"/> <xsl:text>,</xsl:text> <xsl:value-of select="open"/> <xsl:text> </xsl:text> </xsl:for-each> </xsl:template> </xsl:stylesheet> EOF usageData=$(echo "$xmlResponse" | xsltproc /tmp/stylesheet.xslt -) if [[ -z "$usageData" ]]; then echo "No application usage data found for serial number ${serial}." else echo "$usageData" >> /tmp/export.csv fi done # Output file path outputFilePath="${loggedInUserHome}/Desktop/${filename} - ${timestamp}.csv" # Move the file to the user's desktop mv /tmp/export.csv "$outputFilePath" # Notify the user that the report is complete "$jamfHelper" \\ -windowType utility \\ -title "Application Usage Report" \\ -heading "Report Complete" \\ -description "The application usage report has been saved to your Desktop." \\ -button1 "OK" \\ -defaultButton 1 \\ -icon "/System/Library/CoreServices/CoreTypes.bundle/Contents/Resources/AlertNoteIcon.icns" # Invalidate the Bearer token curl -s -H "Authorization: Bearer ${jamfBearerToken}" -X POST "${jamf_url}/api/v1/auth/invalidate-token" echo "Done! Check ${outputFilePath} for the report."
  • March 19, 2025
Thanks for putting thr work in here.
I'm attempting to use this and I'm getting a "Getting a list of devices in Jamf Pro group.
HTTP_Status : 401
HTTP Status Code: 401 : [error] API could not return the group information." error
Any suggestions?
  • 60 replies
  • June 16, 2025
HTTP_Status : 401
Any suggestions?
it looks like it is using the classic API, so be sure to use the correct credentials when authenticating for the calls...
Cookie policy
Cookie settings
