Script for Removing User Folder
  • September 9, 2013
  • 5 replies
  • 0 views
Forum|alt.badge.img+22
  • 289 replies
Sorry total scripting newbie here. I am trying to remove a user folder via a shell script in Casper Imaging that used to work great in DeployStudio:
rm -R /Macintosh HD/Users/apple
I placed this .sh file in a config in Casper Admin, kick it off and the user folder is still there on reboot. has to be something in my syntax?
For a frame of reference what I am trying to to:
We lend users laptops with a local account on them, and then when the person returns the laptop, we wipe that user folder so the next person that uses the laptop doesn't see any of the previous web browsing history, files etc.
Best answer by mm2270
So, a few points.
First, I'm presuming from your post this would be running from an imaging setup where you won't be booted to the Macintosh HD. In that case, you need to include the full path, using /Volumes/, like this:
rm -rfd /Volumes/Macintosh HD/Users/apple
Second, Not sure if the above script lines are exactly what is in your script, but the backslash in the path to "Macintosh HD" needs a space after it, not before. You currently have
/Macintosh HD/
and, including the above point, it should be:
Backslashes go before the character to be escaped, in this case a space. But... you could also just quote the whole path and not worry about spaces or other characters.
rm -rfd "/Volumes/Macintosh HD/Users/apple"
  • 1007 replies
  • September 9, 2013
in a script -rf might be more helpful than an interactive -R
  • 289 replies
  • September 9, 2013
Thx I should have mentioned that I was originally trying -rf and since it didn't work I tried -R also
  • 7883 replies
  • September 9, 2013
So, a few points.
/Macintosh HD/
  • 48 replies
  • September 10, 2013
We have had many issues with scripts not running during imaging, we have to set them to run at reboot for them to work.
  • 289 replies
Thx for all the detail on the full path! With your direction I see that I had a misplaced ""!
Script works perfectly now. really looking forward to gaining some scripting knowledge next month at JNUC :-)
Cookie policy
Cookie settings
