Script Parameter for Set Distribution Point
  • April 22, 2015
  • 7 replies
  • 45 views
Scripts in Casper has predefined variables for $1, $2, $3 where
$1 = Mount point of the target drive
$2 = Computer name
$3 = Username
In my script, I want to curl from the distribution point (set during Casper Imaging).
Is there a predefined variable for this? If not, how can I capture it in a variable?
Thank you,
TT
bentoms
Forum|alt.badge.img+35
  • April 22, 2015
@ttruong can you give more information on what & or why?
  • April 22, 2015
This application has a package with an add-on file. I need to run the package installer within a directory that includes the add-on file for the installation to be succesful. In my script I'm curling a tar file, extracting the tar into tmp, cd into the directory, and run installer -pkg.
The problem is, we have multiple sites and I don't want to have multiple scripts, for each http:// distribution point for each site. I'm hoping there's a way to capture the distribution point into a variable, based on the selection during Casper imaging. I'm aware I can just bundle everything into a package, but I want to make this work with the given script.
Here's the gist of the script:
PAK=sc_tmsminstall.tar.gz
PAKEXT=tmsminstall
SERV1=sc-mmserver3
downloads installer
echo "Downloading TrendMicro from Distribution Server..."
cd /tmp
curl -O -k http://$SERV1/CasperShare/Packages/$PAK
Unzip and install
echo "Extracting and Installing..."
tar -xzvf $PAK
cd $PAKEXT
installer -pkg $PAKEXT.pkg -target /
Removes installer files
echo "Removing installer files"
rm -rf /tmp/$PAKEXT
rm /tmp/$PAK
bentoms
  • April 23, 2015
@ttruong Hmm.. I'd go with a PKG & let the JSS handle the logic of which DP to install it from tbh.
I know you've discounted that, but why not let the JSS do the heavy lifting?
  • April 23, 2015
Even with a PKG, I would need to write installer scripts for each. Anyway, if there's no way of extracting the selected Distriubution Point, I have no choice.
bentoms
  • April 24, 2015
@ttruong looking at the above script. All you need is the PKG on the DP.
Then via the JSS cache that PKG locally & install it.
I'm still missing the need to script it off of the DP.
  • April 24, 2015
I need to run the installer with the add-on file in the same directory. How would I do that using JSS cache?
bentoms
  • April 24, 2015
@ttruong Sorry I didn't see that in the above.
Hmm, what I've done for Sophos is create a DMG of the folder that has the installer & needed additional files.
That's "installed" to a location, then a script runs the installer & tidies up.
