Script: Quickly create package from simple application bundle
I wrote a script I have found to be very useful for quickly making component package files from simple application bundles that are typically downloaded within disk images or zip files. The resulting package files are NOT product archives suitable for uploading to Apple, but are ideal for deployments via JAMF PRO. Use at your own risk.
create_package_from_app_bundle.sh
scottb
  • January 12, 2017
Cool @athomson . Seems to work nicely. Thanks for sharing...
  • February 18, 2017
@athomson Good Afternoon!
Great scripts thank you for your work posted here.
Please forgive my ignorance with this script. I can't seem to get it working and not sure what I'm doing wrong. I have put Terminal in ROOT user mode and still it will not work. Keeps saying permision denied. What am I doing wrong? I would love to use this one and have already implemented the Hard Drive wipe one in Casper and will test it this coming week.
Have a very great day my friend and thank you for all that you share!
I moved a bit further along but I now get this error when running it:
ERROR: Unable to set permissions.
Exited with code #126 after 7 second(s).
Any clue? Have a great day!
  • February 20, 2017
@skinford
Have you tried running:
sudo sh /pathtowhereyousavedthescript/scriptname.sh
  • February 20, 2017
@hjcao Thanks for the tip.
I did try and I still get the error. Weird It looks like it should be working. Here's my script feedback:
/Volumes/Firefox/Firefox.app
Application Name: Firefox
Application Version: 51.0.1
Application Identifier: org.mozilla.firefox
Application Source: "/Volumes/Firefox/Firefox.app"
Application Destination: "/Applications"
Exited with code #126 after 4 second(s).
I found a bit more here is what the error code means: 126 - if command is found but cannot be invoked (e.g. is not executable)
  • February 20, 2017
/Volumes/Firefox/Firefox.app Application Name: Firefox
  • February 22, 2017
on github is app packager which does the same thing from either a dmg with a drag and drop install or directly from an installed app. I use it quite a lot.
  • February 22, 2017
@marklamont Good Morning!
Thank you for the tip. I downloaded it and it seems to work fine. Funny that's the way the window looked when I tried to turn @athomson script into an app using Platypus
I do appreciate the heads up. Have a great day and if anyone needs anything please let me know.
Cookie policy
Cookie settings
